Which engine will be best?
I am pylon racing in an upcoming event. The plane I will have for
the race is an aresti (40size). My question is the best engine for
this plane. The rules require us to use only up the kits
recommended size engine which is up to .58 2-stoke or up to .72
4-stoke.These are what I will have to choose from
OS46FX
Saito56 4-stoke
Which will give me the best overall performance?
David
OS46FX
Saito56 4-stoke
David
Banned
NC
The 46FX will give you better performance, especially in the speed department. Try an APC 10" x 7", and if that doesn't give you enough speed, try an APC 9 x 7. If the 10 x 7 loads the engine too much, and you actually lose speed with the 9 x 7, try an APC 10 x 6 or 11 x 6.
Try the props and don't worry about the ground rpm's too much. The 7" pitch props should unload better in the air, and you may need to go slightly richer on the ground, so that you don't go lean in the air when they unload.
