Paint on the Mylar?
TX
Paint on the Mylar?
Randy E. in MN has a very nice technique to make wings that are as good as "painted in the mold" 428 wings but which are legal for 424 and Q-25. Question: What thickness of mylar is used and where did you buy it? Thanks!
FL
RE: Paint on the Mylar?
Here is that thread you are wanting from Randy Etken. Post #15 says he uses .014 Mylar from CST.
http://www.rcuniverse.com/forum/m_34...tm.htm#3408716
My Feedback: (10)
MN
If you work at it you will get it, took me 3-4 tries to get it right. I now make all wings in a mold, the end product is better and surprisingly less time to make but cost is more. If you have any questions, just ask.
TX
Thanks Randy. I am interested in the technique for 424 and Q-25 where molded wings are not allowed. Your method seems to be able to provide a near-molded finish that meets the rules of 424. Before you switched to molds, did you have a chance to try the 0.010 mylar that you mentioned? I'm going to order some and I'm curious as to whether to order 0.014 or 0.010. Thanks.
My Feedback: (10)
MN
.014 mylar worked the best.The idea to use .010 was to get the leading edge finished more, but this did not work, still had about a 1/4" on the leading edge that needed to be finished and the .014 worked better. Also I used KlassKote paint. This is excellent paint butwill not blend in when you do your leading edge and extremly hard to rub out the paint lineon the leading edge. I now use PPGConcept single stage very easy toblend in withan airbrush but twice the money
