dle55 smoke?
dle55 smoke?
Hello,
I would like to have the smoke on my yak55M.
an idea of what accessories I need?
what store I can buy with good price.
it is possible to manufacture the pump smoke?
thank you
thank you
RE: dle55 smoke?
I just found this on ebay
what do you think?
is a simple copper tubing tour in?
a diagram that explains?
Thank you
I would save € 100 + pot elbow!
what do you think?
Thank you
RE: dle55 smoke?
We offer a smoke pump specifically designed to be a smoke pump. Take a look and let me know if you have any questions.
Chad
http://www.sincityjets.com/store-turbines.htm
Chad
My Feedback: (28)
RE: dle55 smoke?
I used this one on my GP Cap 232 with the OS 160. It runs on 6 to 12 volts and adjusts with the end points on your radio. I loved it and could get amazing smoke out of mine. I ran one loop of brass fuel tube around the head and then right into the muffler with a check valve. Sweet smoke.
Wish I could have got a video of the smoke before I got shot down.
http://www3.towerhobbies.com/cgi-bin...&I=LXDES4&P=ML
Don't spend your money on anything else.
RE: dle55 smoke?
ORIGINAL: CowboyLifesaver
hello,
you use with lipo? or NiMH? you use an ESC to control the voltage?
My Feedback: (10)
OH
RE: dle55 smoke?
If this is for a DLE 55 all you should have to do is tap the muffler for a fitting to allow you to attach a line for smoke oil. Add you smoke oil pump and you should be good to go. Gas engines are not like glow and do not need the extra copper tubing in the muffler to give the oil time to heat up.
Rich
Rich
