Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
pull-pull rudder cable question
Reply
Old 12-05-2010, 01:30 PM
q8cub
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default pull-pull rudder cable question
On a 50cc yak, one of the two pull-pull cables has a "twisted" spot in the middle of the cable. It is not a knot but it looks like the cable has been twisted and created a small half twisted part in the middle.
Should I worry about this and replace this cable ?
I showed this to experienced fliers at the field and most did not think it is an issue, except for one guy who thought his cable got cut off because of a twisted cable.
I am hesitant to fly with this worry on mind and the same time feeling lazy about replacing the cable.
Will it be safe with this situation? i.e. can the cable sustain the tension with this "twisted" spot in the middle of the cable?
Thanks in advance!
q8cub is offline
Old 12-05-2010, 01:36 PM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pull-pull rudder cable question
Personally, if something on my plane worries me at all, then it gets replaced. Think of it as a safety issue and you cannot be too safe when flying larger models, or any model for that matter
bubbagates is offline
Old 12-05-2010, 01:48 PM
phantomdriver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cable is cheap & easy. Seems like I always see another way I'd like it to look anyway after I install.
phantomdriver is offline
Old 12-05-2010, 01:59 PM
q8cub
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys for the advice.
Actually there is another factor here. I called local hobby stores here and non had similar cable (steel cable). Also, I am not sure what type of fishing line I can use as a replacement.
Given this, can the streel cable break because of rudder tension at his spot? What are the chances:10%, 5%, or maybe 1%? or ZERO%!!!
Thanks again.
q8cub is offline
Old 12-05-2010, 03:25 PM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
100% chance. Just no telling when.
The twist as you call it, is a kink, and severely weakens the cable
pe reivers is offline
Old 12-05-2010, 03:47 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with PE here. I would replace the cable but would do so with Kevlar cable availabe from ACP. The reason for the Kevlar is it is lighter, won't strech over time, you need not worry about kinks and has no possibility of creating any RF issues.
speedracerntrixie is online now
Old 12-05-2010, 05:15 PM
blikseme300
My Feedback: (118)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get all my pull-pull cables from the fishing department at my local WallyWorld. The also sell the ferrules and crimping pliers. No need to buy "hobby speciality" cables.
Bliksem
blikseme300 is offline
Old 12-06-2010, 06:48 AM
Jonathan Ott
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: blikseme300
I get all my pull-pull cables from the fishing department at my local WallyWorld. The also sell the ferrules and crimping pliers. No need to buy ''hobby speciality'' cables.
Bliksem
Same here!
Jon
Jonathan Ott is offline
Old 12-25-2010, 03:34 AM
clarencem
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is it exactly that you guys are buying for your pull pull??
clarencem is offline
Old 12-25-2010, 05:32 AM
nute12
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use kevlar string on my ultimate for rudder and elevator. stuff is amazingly strong and super light. I just crimp the ends with the swedges and put heat shrink over em.
I think the cable they are talking about is downrigger cable. find it at any store that carries much fishing goods. i just didnt want long steel strands on mine.
nute12 is offline
Old 12-25-2010, 05:47 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Replace the cable, but find out why it's twisting. Is there a 4-40 threaded part that's unscrewing and coming loose? It'll just happen again if you don't identify the root cause.
JoeAirPort is offline
Old 12-27-2010, 05:30 PM
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I 2nd Joe's post above about finding out why it twisted or you will have the same problem again. I also agree with the others saying to change it.
Jezmo is offline
Old 01-27-2011, 06:30 AM
kmtranmd
My Feedback: (71)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the Kevlar line from Troy Built Models (yellow color) that they claimed was rated at 1000oz and it snapped after less than 10 flights. Granted, it's on my big 150cc 3W Extra which may be extreme. I then replaced with the thick black coated kevlar line from Don's Hobby shop. What lines are you guys talking about from fishing shop that can handle 1000oz or more and has nice coating? I cant seem to find one at Dick's sporting goods or Walmart for my smaller 50-100cc planes.
kmtranmd is offline
Old 01-27-2011, 09:34 AM
awesome
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stripped a plastic servo wheel on a 62cc SD Yak once. Made for an interesting landing. Now i only use double locking ally horns.Snap a cable and find out for yourself.
awesome is offline
