Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Reply
Old 12-22-2012, 01:50 PM
  #1401
kittykatjaz
kittykatjaz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
ORIGINAL: RichardGee
Jaz,
Sorry for the delayed response...
The Flying Wire mounting bolts are 3mm.
Here are two pix:
Argh!!!
I took the no response as I was barking up the wrong tree and reading too much into it so I drilled them all to 4mm a few days ago.
Do you think that they are now all 4mm will be an issue?? The brass on the wire mount holes is a bit thinner now but still over a 1mm thick.I have had the wings on and tensioned since drilling them to see if they loosen up and it has held tension so far.
Just in the process of fitting the side hatch at the moment.
kittykatjaz is offline
Old 12-22-2012, 05:13 PM
  #1402
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No harm... no foul!!
This now give you the opportunity to cut very short lengths of brass tubing and glue them into your flying wire mountiing holes in the wood blocks in the wing.
Do this now, and you will NOT have to do it later!!
You see, the extremely high tension and vibration of the flying wires makes the wooden holes OBLONG such that after some flying time, your flying wires will require tightening.
IF you line the holes with short lengths of brass tubing, it will prevent this from happening and your flying wires will remain perfectly tensioned, while the wing holes will NOT wear out.
RichardGee is offline
Old 12-23-2012, 12:27 AM
  #1403
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My flying Wire mounting bolts are 4mm ;-)
hannes83 is offline
Old 12-23-2012, 12:32 AM
  #1404
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more building pictures from Germany:
hannes83 is offline
Old 12-24-2012, 11:00 AM
  #1405
40GeeBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are those illuminum brackets on top of the landing gear struts, was that kitted or something you have added?
40GeeBee is offline
Old 12-26-2012, 03:21 AM
  #1406
kittykatjaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Spent this evening with a new incidence meter checking the wires done by the previous owner and I have to de-solder and extend one lower hard wire plus replace the twisted braided wire on one side from the undercarriage to the fuse as it is way too short.
So some more questions.
I picked up a couple of the Benzomatic Nickel Silver brazing rods, do you think they would be ok for the wires? See photos for description.
How much of the soldered end of the wire would be safe inside the brass fitting? The one wire which needs extending has to come out around 3 to 4mm to get a safe bite on the threads.
As I have to replace one side of the braided wire, who would know of a suitable replacement without having to chase down a whole wire kit from CARF?
Jaz
ID:	1833838   Click image for larger version
ID:	1833839   Click image for larger version
Old 12-28-2012, 10:13 AM
  #1407
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My new pillow, it´s real leather!
hannes83 is offline
Old 12-28-2012, 10:21 AM
  #1408
rcnut101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks really good Hannes. You got me thinking of evolution radial as well. Im await your flight with new motor. Keep up the good work.
rcnut101 is offline
Old 12-29-2012, 10:14 AM
  #1409
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some work today:
hannes83 is offline
Old 12-31-2012, 10:31 AM
  #1410
rowdog_14
rowdog_14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Us little guys here are trying to get just one CompArf GeeBee and you have three of these bad boys. Nice work keep it up.
rowdog_14 is offline
Old 12-31-2012, 10:36 AM
  #1411
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the Gee Beeis ready for the markings/decals**
hannes83 is offline
Old 01-06-2013, 08:30 AM
  #1412
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was time to make PERFECT markings for the Gee Bee - we needed one week only for the computer work!!
hannes83 is offline
Old 01-06-2013, 02:14 PM
  #1413
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hannes83 is offline
Old 01-06-2013, 09:50 PM
  #1414
kittykatjaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Could those who have completed the CARF Gee Bee post their final dry weight ready to fly?
Mine with the DA150 with KS Alloy canisters less additional weight to balance comes in 16.295kg or 35.92lb.
To balance as is with the tail setup as standard, no pilot and all the batteries mounted directly to the back of the engine dome it will require an additional 700 grams of weight in front of the engine.
So I am going to move the switches and receiver forward in the fuse and lighten what I can in the tail. As well space the engine forward an additional 5mm which will not require mods to the canister exhausts. Even with moving this around and if I manage to get rid of the lead I cannot see this plane being 35 pounds or under.
The plan is to maiden the plane sometime in the next couple of weeks then order the graphics to finish it off.
Jaz
Old 01-07-2013, 01:49 PM
  #1415
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more:
hannes83 is offline
Old 01-08-2013, 11:29 AM
  #1416
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hannes83 is offline
Old 01-08-2013, 04:05 PM
  #1417
greatlakesgunny
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice touch
greatlakesgunny is offline
Old 01-09-2013, 12:47 AM
  #1418
brezel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@Hannes: WOW -speechless-
There´s so much love and enthusiasm in your Gee Bees, especially in this one, i´m impressed!
I am afraid for this model, experience says, that the more you invest in an model airplane, the shorter is it´s life.....
Hate that, brake that, Hannes!
Best wishes,
Wolfgang
brezel53 is offline
Old 01-16-2013, 11:44 AM
  #1419
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Wolfgang, I do my best** :-)
hannes83 is offline
Old 01-16-2013, 11:46 AM
  #1420
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here some new pictures from Germany:
hannes83 is offline
Old 01-17-2013, 09:57 AM
  #1421
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The CHAMPION stickers arrived****
hannes83 is offline
Old 01-17-2013, 03:00 PM
  #1422
invertmast
My Feedback: (22)
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hannes,
Would you be interested / willing to provide a set of your decals for a 26.5% GeeBee R2? I've got everything necessary to finish my scratch built geebee except paint and markings, and would love to get a set of your markings from it.
Thomas
invertmast is offline
Old 01-17-2013, 09:35 PM
  #1423
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo Thomas,
no problem, the markings are available at www.schaurich.de
Write a email to Dieter and order the stuff, he is the owner and will help you.
Hannes
hannes83 is offline
Old 01-18-2013, 11:21 AM
  #1424
invertmast
My Feedback: (22)
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hannes,
Thanks!
Old 01-24-2013, 01:48 AM
  #1425
hannes83
hannes83's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The way to cool the radial down***
hannes83 is offline
Contact Us Archive Advertising Cookie Policy
