If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 51 of 74 FirstFirst ... 41495051525361 ... LastLast
Results 1,251 to 1,275 of 1831
  1. #1251
    Join Date
    Apr 2008
    Orange, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
    More Pics
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1770581   Click image for larger version.
  2. #1252
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking good Nexus...nearly nine months since I have worked on mine and will be getting the Big Hog down today to resume the construction...going to have a custom hub built for the DA170. Plan is to build the hub from brass to counter the tail weight created by the tuned pipes. Will do it last in order to make the hub the correct weight. The first thing in resuming the build is to deal with the wire attachment and wing dihedral. The wires are cut and soldered and for any of you are reading this, was that incidence setting for the dihedral 4 or 4 1/2 degrees?? Sure would save me some reading in this thread if anyone would throw that info in for me.
    Thanks Jimmy
    "Go low if you wanna make a show"
    P-40 Brotherhood #49
    Jimmy
  3. #1253
    RichardGee's Avatar
    Join Date
    Oct 2002
    Dixon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have lightened both the rudder and tail posts and did not notice any ill affects in flight.
    This is all just dead weight that adds little to the essential structural integrity.
ID:	1770839   Click image for larger version.
    The older I get, the faster I was...
  4. #1254
    RichardGee's Avatar
    Join Date
    Oct 2002
    Dixon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hannes,
    Your Gee Bee looks SO GOOD! What did you do to make it look so scale? There is something different... I cannot really put my finger on it... it seems to sit in a more scale position??
  5. #1255
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not a comp-arf, but here is my scratch built 26.5% version (still need to get the nomenclature/stickers for it and paint)
    Thomas W.
    Scratch built: 1/7 F-14D Tomcat, 1/4 TA152H, 1/6 EA6B Prowler up next?
  6. #1256
    RichardGee's Avatar
    Join Date
    Oct 2002
    Dixon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jimmy,
    The Granvilles (Pete Miller) designed the airplane with 4.5 degrees of dihedral. However, it has been determined that a little more helps with directional stability. IF you can manage 5 or even 5.5, you will be better off and will never notice the deviation from exact scale.
  7. #1257
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Richard great post.... I'll fire up the Dremel
    Jimmy
  8. #1258
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks again Richard 5-5.5 it is
    Jimmy
  9. #1259
    tridente's Avatar
    Join Date
    Aug 2008
    DonauwoerthGermany, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    first sorry for my bad english - last english lesson in scool is some years ago...
    I am andreas from germany. Last week i also ordered a geebee r2 from carf.
    All my friends told me: andreas, are you drunk or on drogs...[X(]???
    However - now some days and 51 sites of this thread later i am less anxious about building and flying the R2
    Thanks to Richard an Hannes for your flights, work and feedback here in this forum!!!
    For the maiden, i will take the setup of post #1156.
    My R2 is currently just under construction and i am very happy about this...
    Prost
    Andreas
    Regards Andreas
  10. #1260
    RichardGee's Avatar
    Join Date
    Oct 2002
    Dixon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Andreas,
    Congratulations on joining the CARF Gee Bee fraternity!!
    I wish to make a CORRECTION to post #1156 Set up...
    Everything remains the SAME, EXCEPT my statement about Rudder to Throttle mixing.
    I have flown the Gee Bee both ways, and concluded that NO mixing was the preferred set up. HOWEVER, this was due to my mixing being WRONG!
    The optimal set up is to have right rudder mix begin at about 50% power. The deflection should be 1mm at 50% and should increase to 2mm total right rudder deflection at 100% power.
    Of course, every airplane with be a little different and pilot preference is also different, but the CORRECT MIX will in fact make the Gee Bee easier to handle. (just as the wrong mix will make it more difficult to handle)
    Your English is GOOD... but you might want to reach out to Hannes as I am sure he can communicate in much more technical and specific terms to help you out.
    GOOD LUCK! We want PICTURES
  11. #1261
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Richard,
    Thanks for exact discription for rudder-mix. I will try it so.
    The last days i am in contact with hannes (danke fΓΌr deine Tipps Hannes) i am glad to live only 100km beside him.
    In time my R2 is at a friend, who has more experience in building.
    In some weeks i get it back, than i will make pictures for Forum here.
    Regards Andreas
  12. #1262
    hannes83's Avatar
    Join Date
    Aug 2010
    Kaufbeuren, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Immer gerne Andreas
  13. #1263
    hannes83's Avatar
    Join Date
    Aug 2010
    Kaufbeuren, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More pictures from Germany:
  14. #1264
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A very nice hangar
    Regards Andreas
  15. #1265
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RichardGee
    We want PICTURES
    Hello,
    here are first pictures from building [8D]
ID:	1774352   Click image for larger version.
    Regards Andreas
  16. #1266
    Join Date
    Apr 2008
    Orange, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Andreas (AKA tridente) Are you Setting up for a Moki Install? I was Curious Because I am too. I noticed in your pictures the Bolt pattern for the Engine is Very Similar in nature for a MOki install, Not to mention the Carb or Ventury Way... Nice Job on your Dome!
  17. #1267
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    yes, my first choice will be a moki 250. I flow this engine the last month in my SU31, and i know him well.
    If i understand the comments here and the manual right, i reliable engine is just as important as low weight.
    The Moki maybe is to heavy but 100% reliable and i love this sound...
    If builiding is ready, i measure the weight and decide if the moki can stay in the geebee or i must take a lighter engine.
    Regards Andreas
  18. #1268
    Join Date
    Apr 2008
    Orange, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Andreas, The Moki 250 has been flown In The Gee Bee and it flew it well however from what I understand it is a handful. It only means NO ROOM FOR ERROR!
  19. #1269
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Nexus,
    I hope this is the right time for moki in my geebee.
    In this thread are many important tipps, and i can take a look on hannes's geebee bevor maiden.
    I am looking forward
    Regards Andreas
  20. #1270
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I looked this video: http://www.youtube.com/watch?v=FAgq4...e_gdata_player
    At 3:17min after landing it looks like as both ailerons are set a little down like flaps.
    Can anybody confirm that?
    Regards Andreas
  21. #1271
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had planned initially on a DA170 but have decided to wait on this beast
ID:	1775155   Click image for larger version.
    Jimmy
  22. #1272
    rowdog_14's Avatar
    Join Date
    Sep 2005
    Austell, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Man I would love to hear that bad boy!!!!!!!!!!
    THE T.R.U.T.H
  23. #1273
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    i have 2 questions:
    - Did you use the original shock-absorber in the landing gear ore otherΒ΄s.
    - What prop would you recommend me for the moki 250.
    In my SU i flow a 32x18. this was perfekt. I read here, that the ground clearance maybe is with 32" to small...
    A 30x20 is not available? The moki turns the 32x18 on floor between 1000 and 4.300 U/min.
    Regards Andreas
  24. #1274
    tridente's Avatar
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The engine take seat
    Regards Andreas
  25. #1275
    Join Date
    Apr 2008
    Orange, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Andreas... Yes the Stock Shock Absorbers Work well and I believe Everyone has been using them with no problems. Although with the Mokies up front the absorbers may need to be stiffened up a bit with a heavier spring or not, Still waiting to see what my finished weight is going to be with mine. I was chatting with Gotz at Aero-Scale, he knows these Mokies inside and out and he suggests going with the 30x20 Wood Prop. This will be the Most Efficient for this Engine, but also good speed. Your Moki Mount looks great. Here is mine.
ID:	1776468   Click image for larger version.
ID:	1776469   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
