I just bought a used SD YAK 35% with a dle-111 engine.
Can I use the following servos:
savox SC-0251 servos on elevator (2) and aileron (4). Each is 16 kg torque
One JR 8711 (29 kg torque) for rudder
specs for savox sc-0251:
Modulation: Digital
Torque: 6.0V: 222.1 oz-in (15.99 kg-cm)
Speed: 6.0V: 0.18 sec/60°
Weight: 2.15 oz (61.0 g)
Dimensions: Length:1.60 in (40.6 mm)
Width:0.79 in (20.1 mm)
Height:1.66 in (42.2 mm)
Motor Type: Brushed
Gear Type: Metal
Rotation/Support: Dual Bearings
Would this be sufficient?
Thanks in advance!
