Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
DLE 30 Prop hub replacement and install
Reply
Old 10-05-2012, 06:17 PM
scvsteve
scvsteve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DLE 30 Prop hub replacement and install
I have a DLE 30 gas and 2 of the bolts that go into the prop hub are broken off. I have ordered replacements but how do I remove the old hub from the shaft. I may be able to grab both the shaft and hub and twist them off but will that damage the key. Also if that works how do I tighten down the new shaft and hub?
Here are the new parts http://www3.towerhobbies.com/cgi-bin...0&I=LXYUT9&P=K
scvsteve is offline
Old 10-10-2012, 09:58 PM
kerwin50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DLE 30 Prop hub replacement and install
There is a nut/shaft that you have to unscrew. then the hub slides off. If you look at the parts you ordered you can see the nut I'm talking about.
kerwin50 is offline
Old 11-18-2012, 08:06 AM
JoeAirPort
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Remove the prop shaft by attaching an old prop or hand made tool (using prop bolts) to hold the hub while loosening the prop shaft. Then use a gear puller to pull the hub off. Or use a prop drilling jig to pull it off. After that installing the new one is the easy part. One thing is for sure, the hub does not just slide off after the prop shaft is removed.
You have two threads and have already resolved the issue on the other one. Nice. Now I know why I never go on RCU anymore.
http://www.rcuniverse.com/forum/m_11...m.htm#11257671
JoeAirPort is offline
Old 11-18-2012, 09:43 PM
nitro wing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, was surprised that JoeAirport responded, so many people have left..its a quiet ghost town on RCU []
nitro wing is offline
Reply
Display Modes
