Giant Ugly Stick
Giant Ugly Stick
Hi all
I am getting ready to build a Giant Ugly Stick (Model Builder Version), I am in the process of finding all the hard to get bits.
This is where I am up o:-
Plan
Model Builder Magazine from 1979
Engine :- Webra Bully 35 Glow engine as new with a 20x8 Master airscrew and a tru turn spinner
Muffler :- Tatone Universal from the nice guys at MECOA
Nose Leg :- FULTS RF700 On order
Servos:- I have 2x FP34 1/4 scale and 4 x Hitec HS400 1/4 scale Servos (They are not the newest but should work fine)
Large amount of 1/4 x 1/2 inch spruce
Wheels I have 2 x 1/4 cub wheels and one Dubro 4 inch wheel for the nose.
Undercart :- ??? Do I make one or can I buy one?
Wing Ribs:- Do I cut my own or buy a short Kit? $169.00, or can you just get ribs laser cut anywhere? everything else is easy to make just big.
Has any one else built one, do youhave any tips what not to do?
Any input would be helpful
Johnkpap
Plan
Johnkpap
RE: Giant Ugly Stick
How much work do you WANT to DO??
AMR makes a nice series of kits for the Stick, several sizes, High wing & Low wing even a twin. All lazer cut and fully equiped.
http://www.amr-rc.com/
Yours to consider.
Good Luck!
Yours to consider.
Good Luck!
Thanks for the input
The ribs for the Model Builder GIANT STICK, look like hard work......yes i could do them on my band saw and scroll saw, but they would be a pain
as they are made of a rib plus 2 sub ribs.
I am going to keep my bully 35 as a glow engine, less stuffing around I am not that worried by my fuel bill as the the engine only needs 5-10% oil and at the most 5% nitro,I suspect being a Webra it will be quite happy on no nitro , the largest cost when mixing fuel is the OIL and nitro here in the land down under.
I have decided the best way will be to order a short kit from Laser Cut kits Australia, this will make life easer.
I will post some pic's of the kit once I order it
Has any one else built a Giant Ugly stick?
Johnkpap
Johnkpap
ORIGINAL: Johnkpap
...Has any one else built a Giant Ugly stick?
Johnkpap
Johnkpap
I built that one.If it is 90" wingspan? I put a 45 on it I cut the parts in a couple of hours, very easy to do. give it a go. .http://www.rcuniverse.com/forum/m_90...tm.htm#9083396
