smoke tank placement for correct CG
My Feedback: (38)
Iposted this in the giant scale and have not had much luck, then I thought about this forum and with all the aerobats here, surely I will have better luck So here is the situation
I am finishing up my build on my GP 1/3 scale pitts special, I have a question about the location of the smoke tank, I have all my accessories located, batteries, ignition, etc,,
Here is my question,, Where should I put the smoke tank in regards to CG,, I have the plane balanced right now with the engine (dle-55), smoke pump, and batts,,
I was thinking of putting the center of the smoke tank right on the CG of the plane, that way It would not throw the plane out of balance when it gets filled, I balance the plane with an empty fuel tank, and it is located in forward of the cg, So I know I dont want any more weight on the nose after the fuel tank is full, thats why I was thinking center the smoke tank right at cg,
If my thinking is wrong please help me out, I am asking for advice, I know plenty of you guys have probably figured this out the hard way, and I am wanting to learn from your experience,, thanks fellas
RE: smoke tank placement for correct CG
A minor point but I would recommend swapping the 2 fuel tanks. You want your main fuel tank for the engine on your CG as you will always need to be flying with fuel for the engine. That way, under normal circumstances, there is no CG change when your flying without smoke. When you do use smoke, your CG will be forward but you probably don't fly with smoke all the time and when you do, the smoke oil tends to be used up quicker than the engine burns fuel so you'll be nose heavy a smaller percentage of your overall flying time (rather than always).
ORIGINAL: raron455
thanks fellas, I wanted to get all the advice I could before placing it,,
If you cannot place the fuel and smoke tanks in the CG, but forward; then, both should be empty for balance.
Yes, the plane will be nose heavy for take-off, but will be balanced for landing.
The inverse applies for tanks that need to be placed aft the CG (they should be full for balance).
