Byron/Iron Bay AT-6 Texan CG?
Steve & Cri Cri , the CG is 5-3/4" aft the LE at the wing root (root of the outer panel)
Drill a 1/8"hole in the upper area of the outer ply rib (of center section) just under the fiberglass lip 5-3/4" back from LE .Do this to both sides , bend a hook in 1/8 piano wire place a hook in each hole and suspend the plane from both hooks. The plane should be slightly nose down . Not unusual to add several pounds.
__________________
__________________
Per instructions :Elevator- 3/4 " up and down
Ailerons - same
Rudder - 2" both directions
Per Me
Elev. 1/2" low , 3/4 mid , max throw high
ailerons - same
Rudder - 1 -1/2 low , 2" mid , max throw high
Use exponential as needed or preferred
Ailerons - same
Per Me
ailerons - same
Byron t6 cg
The plane is upright if suspended by the hooks , because the hole for the hooks are in the upper area of the rib
Inverted if using any other method of balancing
Gear is up in any case
