Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
*Redwing RC 50cc Slick 540 (Electric)*
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 07-03-2014, 04:03 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Default *Redwing RC 50cc Slick 540 (Electric)*
Picked up my plane at our IMAA event from Redwing RC. I have some minor issues and Redwing RC is working with me on it but overall a very nice plane. Seems to be super light which will be great for my first giant scale electric. Here is what my setup will be.
Eflite-Power 360 motor
Phoenix Edge HVF 160 w/Fan ESC
EC5 connectors / 8 gauge wire
EC5 Series connector / 8 gauge wire
2 Glacer 5000 45C 6S packs in series
XOAR (gas/wood) 24X10 prop
4" Tru-Turn Ultimate Spinner
ID:	2011304   Click image for larger version
ID:	2011305   Click image for larger version
ID:	2011306   Click image for larger version
ID:	2011307   Click image for larger version
ID:	2011308   Click image for larger version
ID:	2011309   Click image for larger version
Old 07-03-2014, 04:11 PM
Zippi
My Feedback: (10)
Zippi's Avatar
I used a XOAR 23X8 prop just as a test to see if the prop bolt (4 bolts) pattern was the same as a DLE 55 and it is. I have ordered the DA50 2 1/2" Stand-offs as they are tapped 1/4-20 on one end and that will fit the bolts that came with the Power 360. I also changed out all the pin type hinges that came with the Slick 540 to the Robart 312 3/16" Steel Hinge Points. The Robarts are the same size but have a larger pin in the knuckle. The stock ones would have probably been fine but since I had the Robarts I used them. I had a problem with both stabs not fitting up to the fuse so I removed some of the ply on the root rib on the leading and trailing edge and them added washers to take up the gap between the tabs on the stabs and the fuse. Sold one of my planes so I'm waiting for them to pick it up so I can buy the CC 160HV /Fan ESC. I also have a DLE 35RA I'll be selling to fund the rest of my new electric build.
ID:	2011311   Click image for larger version
ID:	2011312   Click image for larger version
ID:	2011313   Click image for larger version
ID:	2011314   Click image for larger version
Old 07-03-2014, 04:15 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Received my DA50 2 1/2" stand-offs today. had to add 3/16" to get the proper gap between the cowl and the spinner back plate. These stand-offs are really heavy duty.
ID:	2011332   Click image for larger version
ID:	2011333   Click image for larger version
ID:	2011334   Click image for larger version
Old 07-06-2014, 08:15 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Worked on my Slick 540 this morning and got a few things completed. The cowl was not positioned correctly so I had to add another 1/16" (already had 3/16" added to the stand-offs) to all 4 stand-off's. I happened to have some 1/4" aluminum spacers on had so it worked out fine. I also had to add 1/16" washers to both upper cowl bolts to tilt the cowl down a little to line up with the spinner back plate. The 5/8" bolts that hold the wheel pants on are to long and they were hitting the wheel hub and the wheel will not turn. Had to replace them with 1/2" bolts. Also had to use my dremel tool to cut away both sides of the wheel pants on the bottom as they were rubbing against the wheels. Got the tail wheel bracket put on and seems to work fine.
ID:	2012098   Click image for larger version
ID:	2012099   Click image for larger version
ID:	2012100   Click image for larger version
ID:	2012101   Click image for larger version
ID:	2012102   Click image for larger version
ID:	2012103   Click image for larger version
Old 07-12-2014, 09:47 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Started installing the tail wheel assembly only to find out that the small aluminum piece that gets epoxied into the rudder was not long enough and had to be replaced. I took a 2-56 ball link and screwed a piece of all thread rod into it and then epoxied it into a piece of carbon fiber tube. I had to drill through the bottom of the rudder and into the next rib to make sure it was strong enough.
ID:	2013530   Click image for larger version
ID:	2013531   Click image for larger version
ID:	2013532   Click image for larger version
Old 07-13-2014, 01:15 PM
Zippi
My Feedback: (10)
Zippi's Avatar
All connectors are soldered on and the CC 160HV ESC is installed. The round hole in the front of the cowl creates a direct air flow over the ESC.
ID:	2013792   Click image for larger version
ID:	2013793   Click image for larger version
ID:	2013794   Click image for larger version
ID:	2013795   Click image for larger version
Old 07-30-2014, 03:20 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Not much interest on this thread so I will not post anymore.
Old 07-30-2014, 06:17 AM
taildragger21
My Feedback: (197)
taildragger21's Avatar
Zippi I think it's cool... I'm doing a gw Corvus 540 on e power.. Been flying a 33% cub on e power and love it..
Old 07-30-2014, 06:28 AM
krzy4rc
krzy4rc's Avatar
Zippi, are you using a BEC or seperate battery (LiFe?)? I am using LiFe on my 3DHS Edge 540 and I'm considering changing to BEC for weight and to clean up some room.
Old 07-31-2014, 01:44 AM
bladebender
just found it I please post some more thinking about buying that motor to
Old 07-31-2014, 03:44 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Ok.....I had to drill the back plate of my Dave Brown 4" spinner. I enlarged the center hole and drilled the 4 prop bolt holes to fit the Power 360. I also had to enlarge the spinner to except the XOAR 24X10 prop. Sill waiting on a couple servos that are on back order. I'm moving slow on this build so not sure when it will see the air.
ID:	2018791   Click image for larger version
ID:	2018792   Click image for larger version
ID:	2018793   Click image for larger version
Old 07-31-2014, 06:49 PM
NM_Mark
My Feedback: (8)
NM_Mark's Avatar
I had a Goldwing SBach 342 30% plane that I converted from a DLE 55 to electric. My motor was overkill, a Turnigy 8317 (I think) - the motor with two 6 cell 5000 lipo's was actually heavier than the DLE 55 I took out of the plane - but it did have mad power!! It was a lot of fun, I plan to do the same thing to an Aerobeez 30% Yak54. I will be getting a lighter motor this time!
Old 08-01-2014, 03:24 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Yeah, the electric does come out a little heavier but with about a 3-1 power to weight ratio I can overlook the extra weight. Plus, I just couldn't see paying $660.00 for a Hacker Q80-8M which is lighter. My first giant scale electric so we'll see.
Old 08-03-2014, 01:58 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Got a chance to do a little work on the Slick 540 today. I cut slots in the cowl ring to except the 1/2" square hard wood blocks I epoxied to the fire wall for the cowl screws. I had one of the servo trays pop off just by operating the servos. Not a good sign. I removed both the aileron servo trays and cleaned them up and epoxied them back in. I did a dry fit to get a good look at the plane and see what it looks like.
ID:	2019629   Click image for larger version
ID:	2019630   Click image for larger version
ID:	2019631   Click image for larger version
ID:	2019632   Click image for larger version
ID:	2019633   Click image for larger version
ID:	2019634   Click image for larger version
ID:	2019635   Click image for larger version
Old 08-04-2014, 10:50 AM
NM_Mark
My Feedback: (8)
NM_Mark's Avatar
Something to remember, you will need plenty of ventilation with that big motor and ESC up front. I cut holes in the bottom of the plane just behind the wing, plus holes in the cowling for cooling. I have a Sig Sukhoi that I converted to electric power with a Turnigy 6364 motor, and I cut a hole in the bottom for an air exit, then had to increase the size of that opening because the ESC was getting too hot and cutting power after 3 minutes of flight.
Old 08-04-2014, 02:03 PM
Zippi
My Feedback: (10)
Zippi's Avatar
My ESC is right in front of the round hole in the front of the cowl plus I have the CC 160 ESC with fan. I haven't gotten to it yet but I'll cut a couple slots on the bottom of the fuse below the conopy. I'll fly it and see how things go for ventilation.
Old 08-05-2014, 08:35 AM
volcomSNOWs2k
volcomSNOWs2k's Avatar
Cool! Looking forward to hearing about how you like the performance!
Old 08-06-2014, 03:17 AM
Zippi
My Feedback: (10)
Zippi's Avatar
I cut some outlet holes for the hot air to escape so we'll see how this works out. I also heard from Redwing RC that they are shipping me my stabilizer replacements straight from China. My original ones were warped so bad the tabs to secure the stabs to the fuse were 1/8" to 3/16" away from the fuse. I was going to use washers to space it out but I think now I'll wait for the replacements.
Old 08-06-2014, 10:32 AM
NM_Mark
My Feedback: (8)
NM_Mark's Avatar
That looks like plenty of ventilation to me - looking good!!
Old 08-08-2014, 02:01 PM
hunter777
This is my next plane so I am following your build. Looks really good, I am putting dle55 in mine and savox 1231 all around. Like that scheme a lot.
Old 08-08-2014, 02:41 PM
mchadwick
I am working on the Redwing Extra 76' and the Slick 76" in all electric. Build Thread on RCG. This is good stuff here!
Old 08-09-2014, 09:13 AM
Zippi
My Feedback: (10)
Zippi's Avatar
I'm picking away at this build but some where down the road it will be finished. I got the rudder servos installed and the cables hooked up to the rudder. My replacement rear stabs should be here on Monday or Tuesday. Haven't heard anything on my Glacier 5000 mAh 6S replacement yet.
ID:	2021127   Click image for larger version
Old 08-12-2014, 03:32 PM
Zippi
My Feedback: (10)
Zippi's Avatar
I received my new rear stabs yesterday from Redwing RC's factory in china and did a dry fit today and they fit up to the fuse just fine so I installed the servos. I replaced the hinges with Robart hinges as I did on the rest of the plane. I sent an email to Buddy RC to see about my replacement for one of my Glacier 5000mAh 6S 45C. I was told the guy that handles there returns is on vacation. I'm thinking......no one else knows how to ship a battery????????
Old 08-16-2014, 01:29 PM
Zippi
My Feedback: (10)
Zippi's Avatar
I got the tail end all tightened up today. The only thing left to do is program the rates and set the CG. Course I can't do that until I get a replacement battery back from Buddy RC.
Old 08-17-2014, 12:00 PM
taildragger21
My Feedback: (197)
Zippi.. Looks great.. Here is my just finished 89" Corvus 540. Put a rimfire 65cc/cc ice 160hv. Flies great even with the heavier motor
