Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Fly-Model MX2 30cc 3D ARF V2 BUILD !!!
Reply
Old 12-09-2014, 06:49 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fly-Model MX2 30cc 3D ARF V2 BUILD !!!
I got the v2 fly model mx2 it has carbon landing gear wing tube and control horns it also comes with SFG (Side force generators) i have unboxed and stuck it together
and here are some pics
Link http://www.rcuniverse.com/market/ite...itemId=1007808
ID:	2053493   Click image for larger version
ID:	2053494   Click image for larger version
Jerry woodrough is offline
Old 12-12-2014, 05:50 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will be following your build as I just picked up their "thunder Bird" and will start very soon!
what engine are you putting in yours? I will use a 30cc by DLE.
tailskid is offline
Old 12-15-2014, 04:17 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Update !!
The version 2 hardware has been upgraded to carbon fiber control horns, landing gear, and wing tube. Carbon fiber has also been added to the two bottom stringers of the fuselage for added strength. The carbon control horns have a clear protective film which needs to be removed otherwise glue will not stick I also lightly sanded the areas of the control horns to be glued in place to make sure of a secure bond. Overall the instructions that come on a mini cd-rom are fairly straight forward and have a lot of pictures which some times helps where the translation is lacking. So far I really like this kit the fit and finish are great considering the price.
ID:	2055399   Click image for larger version
ID:	2055402   Click image for larger version
ID:	2055405   Click image for larger version
ID:	2055407   Click image for larger version
ID:	2055409   Click image for larger version
ID:	2055411   Click image for larger version
ID:	2055413   Click image for larger version
ID:	2055427   Click image for larger version
ID:	2055428   Click image for larger version
ID:	2055429   Click image for larger version
ID:	2055430   Click image for larger version
ID:	2055431   Click image for larger version
ID:	2055432   Click image for larger version
ID:	2055433   Click image for larger version
ID:	2055435   Click image for larger version
ID:	2055436   Click image for larger version
ID:	2055437   Click image for larger version
ID:	2055438   Click image for larger version
ID:	2055439   Click image for larger version
ID:	2055440   Click image for larger version
Old 12-15-2014, 05:48 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your comments are EXACTLY as I would have said...I have the Thunder Bird and it appears to be the same plane as yours, my Sbach and who knows what else...I too liked the price
Jerry
tailskid is offline
Old 12-21-2014, 06:13 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a video from today enjoy !!! http://youtu.be/msIkiRjB5l4
Old 12-21-2014, 06:45 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow!
tailskid is offline
Old 12-23-2014, 05:31 AM
Rich B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jerry, I would like to ask a few questions on your build if I may.
Did you have to add any additional weight to the plane to get the cg as specified by the manufacturer?
What is your planes assembled weight?
Do the elevator halves have the option to be joined together for the use of a single servo?
Rich
Rich B is offline
Old 12-23-2014, 11:25 AM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rich, I'm still assembling mine, but I can answer the question regarding the stab.....sorry, you will need two servos as there is a rudder in the way. My Sbach (30cc) did not need any nose or tail weight to balance on the CG.
tailskid is offline
Old 12-25-2014, 12:52 AM
Rich B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I asked about joining the elevator halves as I can see in the pictures the cut out in the fuselage that appeared like a joiner could be used to connected the two together... i.e. 3dhs and ef planes.
Thanks, I would appreciate any additional information you can provide on your build.
Rich B is offline
Old 12-25-2014, 10:43 AM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Rich B View Post
.............Do the elevator halves have the option to be joined together for the use of a single servo?
I have the 30cc Sbach, which odds on uses the same manual since mine covered like 3-4 aircraft in one book (99% sure that the MX2 was included within), and mine showed the install of the supplied wooden joiner for joining the two elevator half's together - that said, I went for two servos after covering up the holes at the rear of the horizontal stab that you spotted on the pics above.
Hope that helps some.
kiwibob72 is offline
Old 12-25-2014, 04:02 PM
Rich B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info this far. I hope someone with this plane would chime in as well. Really interested in hearing about the cg on this model... last thing I would ever want is having to add weight to a 3d plane.
Rich B is offline
Old 12-25-2014, 04:36 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rich B
We are running a DLE 30 solar 772 servos 1 life 3600mah running both receiver and radio and the fuel tank it comes with and we have the battery right behind the wing spar and it is perfect
Old 12-25-2014, 06:06 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a link if you are looking to buy http://www.rcuniverse.com/market/ite...itemId=1011275
ID:	2057722   Click image for larger version
ID:	2057725   Click image for larger version
ID:	2057726   Click image for larger version
Old 12-25-2014, 06:09 PM
Rich B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jerry!
Rich B is offline
Old 12-25-2014, 06:13 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anytime
Old 12-28-2014, 03:43 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay review time
The plane for the price is awesome cant beat it, its light its strong looks great and the the build was pretty easy the seller is out standing over all a great experience
this plane is defnetly a keeper
Old 12-31-2014, 03:36 AM
flyboy57id
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What brand covering is on Fly Model planes ?
Gordon
flyboy57id is offline
Old 01-01-2015, 06:01 PM
Joboone3d
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great read. Im ordering the fly model yak54 and putting my dle30 with reed mod and bowman ring. I have read tons of good things on fly model's arfs and seems to be a great buy for the price.
Thanks, Jo
Joboone3d is offline
Old 05-14-2015, 09:44 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any update Jo?
tailskid is offline
Old 02-08-2018, 10:30 PM
awade58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Elevator servos
Are you using a y-harness on the elevator servos?
awade58 is offline
Old 02-09-2018, 03:03 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pretty old thread...
tailskid is offline
