Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Fly Model Green SBACH342 30cc Version 2 Build !!
Reply
Old 01-16-2015, 02:21 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fly Model Green SBACH342 30cc Version 2 Build !!
New Features:
  • Side-force generation (SFG) additon
  • C/F reinforcement in wings and fuselage
  • C/F wing tube
  • C/F landing gear and tail gear
  • PU rubber wheels
  • C/F control horns
Specifications:
Wing Span: 1860mm / 73in
Wing area:1014sq in / 65.4 sq dm
Flying weight: 4400g - 5000g
Fuselage length: 1700mm / 67 in
Engine Required: 30 cc Gas Engine
Radio Required: 4 Channels ; 5-6 Servos
So today I have received my new Fly Model green 30 cc Sbach 342 V2 from RC Jets World when it arrived there was slight damage to the outside box
as you can see in the picture the good thing is that it is double boxed and there was no damage to plane
ID:	2064248   Click image for larger version
ID:	2064249   Click image for larger version
ID:	2064250   Click image for larger version
ID:	2064251   Click image for larger version
ID:	2064252   Click image for larger version
ID:	2064253   Click image for larger version
ID:	2064254   Click image for larger version
ID:	2064256   Click image for larger version
ID:	2064257   Click image for larger version
ID:	2064258   Click image for larger version
ID:	2064259   Click image for larger version
ID:	2064260   Click image for larger version
ID:	2064261   Click image for larger version
Jerry woodrough is offline
Old 01-16-2015, 05:03 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One thing we like to do with any plane is go over the glue joint just to make sure the joints are glued well and it just
makes sure nothing will break loose in future.
The carbon landing gear looks super nice the holes where pre drilled for mounting and wheel pants . (Make sure to use loctite all machine screws and grub screws throughout the build)
The tail wheel is also carbon fiber and super nice one thing we did is after we drill the holes for the tail is
take the screws back out and put a drop of CA in the holes so the screw do not back out and this also hardens
the wood around the screws.
ID:	2064342   Click image for larger version
ID:	2064343   Click image for larger version
ID:	2064344   Click image for larger version
ID:	2064345   Click image for larger version
ID:	2064346   Click image for larger version
ID:	2064347   Click image for larger version
ID:	2064350   Click image for larger version
ID:	2064354   Click image for larger version
ID:	2064355   Click image for larger version
ID:	2064356   Click image for larger version
ID:	2064357   Click image for larger version
ID:	2064358   Click image for larger version
ID:	2064360   Click image for larger version
ID:	2064363   Click image for larger version
ID:	2064368   Click image for larger version
ID:	2064369   Click image for larger version
ID:	2064370   Click image for larger version
ID:	2064371   Click image for larger version
ID:	2064372   Click image for larger version
ID:	2064373   Click image for larger version
ID:	2064374   Click image for larger version
ID:	2064389   Click image for larger version
ID:	2064391   Click image for larger version
ID:	2064396   Click image for larger version
ID:	2064397   Click image for larger version
ID:	2064398   Click image for larger version
ID:	2064399   Click image for larger version
Old 01-17-2015, 10:59 AM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the same plane (but just the V1). From the photo's, yours looks to have the bits of the wings between the ailerons and the fuse made as part of the wing, and not separately like mine was (had to glue mine in place), which alone is a nice upgrade.
From my own experience, watch the very fine points on the lightning bolt covering, mine peeled off by just looking at them too hard. If you have access to one of those covering seam sealer pens/sticks I've seen somewhere, I'd use it!
Glad you got all your stickers too, I had to custom cut the large 'SBACH 342' sticker on the wing, and correct the 'thuderbolt' aileron stickers to read 'thunderbolt' post a trip to the local sign writers for some adhesive vinyl film.
Despite that, I still found it a very enjoyable and rather easy build that made for a VERY nice final product IMO - so much so, I showed the finished product to a guy at the club, and he went out and brought exactly the same thing!
Here is one I prepared earlier!
kiwibob72 is offline
Old 01-18-2015, 05:20 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the heads up I use clear finger nail polish on the tips of monocote trim to keep it from peeling back. Thats one good looking plane you have there!
Old 01-18-2015, 09:00 PM
kiwibob72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Jerry woodrough View Post
Thanks for the heads up I use clear finger nail polish on the tips of monocote trim to keep it from peeling back. That's one good looking plane you have there!
As will your be once your done! LOL!! (and thanks)
Also, if the bottom of the 'cockpit' is painted like mine, the paint my pilot figure was glued to fell off during the first run up of the motor. so if you put one in, take the time to remove the paint first - this is the outcome if you don't: https://www.youtube.com/watch?v=nIVp_F2FnQ4
Noticed that they are including enough servo arms (and hopefully horns) to run dual elevator servos, I had to buy servo arms and horns to run mine with twin servos!
Wondering if who ever packed mine at the factory did so on a Friday afternoon??
Old 01-21-2015, 07:03 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next thing we did is notch out the elevators ruder and ailerons so it has little to none hing gap
then put together the carbon fiber control horns ( be sure to take of plastic covering on them as seen in the pic)
Measure the elevator on both side to get it lined up then mark lines down the fuse and cut out the covering and then measure to make sure it is square with fuse and then glue
then we took some Vaseline and applied to middle of the hinges to prevent glue locking them up and the loctite 5 min squeeze tube works great to get the epoxy into the holes without a mess
tail wheel assemble
servo installation
gluing SFG
assembling the gas tank
drilling holes for the motor mounts and throttle linkage
ID:	2066199   Click image for larger version
ID:	2066200   Click image for larger version
ID:	2066201   Click image for larger version
ID:	2066202   Click image for larger version
ID:	2066203   Click image for larger version
ID:	2066204   Click image for larger version
ID:	2066205   Click image for larger version
ID:	2066207   Click image for larger version
ID:	2066208   Click image for larger version
ID:	2066209   Click image for larger version
ID:	2066210   Click image for larger version
ID:	2066211   Click image for larger version
ID:	2066212   Click image for larger version
ID:	2066213   Click image for larger version
ID:	2066215   Click image for larger version
ID:	2066216   Click image for larger version
ID:	2066217   Click image for larger version
ID:	2066218   Click image for larger version
ID:	2066219   Click image for larger version
ID:	2066220   Click image for larger version
ID:	2066221   Click image for larger version
ID:	2066223   Click image for larger version
ID:	2066224   Click image for larger version
ID:	2066225   Click image for larger version
ID:	2066226   Click image for larger version
ID:	2066227   Click image for larger version
ID:	2066228   Click image for larger version
ID:	2066229   Click image for larger version
ID:	2066231   Click image for larger version
ID:	2066232   Click image for larger version
ID:	2066233   Click image for larger version
ID:	2066234   Click image for larger version
ID:	2066235   Click image for larger version
ID:	2066236   Click image for larger version
ID:	2066237   Click image for larger version
ID:	2066239   Click image for larger version
ID:	2066240   Click image for larger version
ID:	2066241   Click image for larger version
ID:	2066242   Click image for larger version
ID:	2066243   Click image for larger version
ID:	2066244   Click image for larger version
ID:	2066245   Click image for larger version
ID:	2066247   Click image for larger version
Old 01-26-2015, 07:43 PM
Jerry woodrough
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mounting motor
Mounting fuel tank
Mounting and cutting out cowl
ID:	2068101   Click image for larger version
ID:	2068102   Click image for larger version
ID:	2068103   Click image for larger version
ID:	2068104   Click image for larger version
ID:	2068105   Click image for larger version
ID:	2068106   Click image for larger version
ID:	2068107   Click image for larger version
ID:	2068113   Click image for larger version
ID:	2068114   Click image for larger version
ID:	2068115   Click image for larger version
ID:	2068116   Click image for larger version
ID:	2068117   Click image for larger version
ID:	2068118   Click image for larger version
ID:	2068119   Click image for larger version
ID:	2068121   Click image for larger version
ID:	2068122   Click image for larger version
ID:	2068123   Click image for larger version
Old 10-26-2015, 07:10 AM
Boboeing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice build..... So how does this thing fly? I have a DA 35 waiting for an airplane. What do you think?
Boboeing is offline
