Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Battery charging
Old 05-30-2017, 03:34 PM
cotman
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Battery charging
I have a large (105") pawnee with smoke installed. Smoke works great, but every time I want to charge the 6V NiMH battery I have to disconnect it from the Sullivan Skywriter unit, charge it, then reconnect it. Is there a way I can install a on/off switch with a charge port built into the switch. That way I can charge the battery with out disconnecting it. The lead from the Skywritter unit stays connected to my receiver. A quick diagram would be greatly appreciated.
cotman is offline
Old 05-30-2017, 03:48 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take any R/C on-off switch and put it between the battery and the smoke pump. Run the charge connector to any convenient place where you can connect the charger. Dan.
All Day Dan is offline
Old 05-31-2017, 07:08 AM
A. J. Clark
A. J. Clark's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like to use the Ernst holder to mount the charge connector . Mount the connector on the body of the plane then you can charge from the outside.
A. J. Clark is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
