H9 80" cap232 and ZDZ40 info needed
I currently have a H9 cap232 80" which by the way is a really nice looking plane but I can get my hands on a zdz40 for trade with some ducted fan stuff so I am wondering if that engine is good enough for this plane to do hovers, harriers, flat spins, waterfalls etc... and normal IMACC stuff.
I am new to this gas engine stuff so I am not sure how power full this ZDZ40 will be for this plane.
Let me know
Enjoy!
Let me know
Enjoy!
My Feedback: (12)
RE: H9 80" cap232 and ZDZ40 info needed
well i have a hangar 9 cap 80" and i personally love my taurus 52 cc gasser, the plane balanced perfectly with it. I would do it right and get a 50cc!!!!!
so howmuch does your weigh?
I have one here a friend did - beautifulbut weighs 17.25 lbs!!!!!!!!!!!!
the old smaller one was great with the 40 and I am sure yours is flying nicely with the 52 -the problem is LOW speed performance --it falleth
sparkplug,
It needs to be at least a rotory valve model. There are 4 of these Caps flying here with a ZDZ50NG (mine), older ZDZ50 (1300 rpm lower than the NG), ZDZ40RV and a Zenoah G42. The lowest performer is the G42 and the highest performer is the ZDZ50NG. The 40RV flyies very nicely.
Victor
Victor
Do a searh for Fishgod, he had this same setup. He liked it at first, but later decided it did not have enough power to do hovering and some IMAC stuff.
I switched the ZDZ50 in my friend's plane -to my new ZDZNG and the performance increase was dramatic .
The big problem with the earlier ZDZ50 is not the engine as much as the muffler used.
The std Bisson used on a number of these - is quiet but is also restrictive - try th same muffler -on a DA 50 and it reduces power .
A goodZDZ 40 on a good open muffler or tuned setup will pull it just fine.
If using the non NG model 50 - get a open flow muffler or cut tips from the Bisson.
So far -we have seen nothing in the 50 size engine that compares with this new NG - on a free flowing muffler - keep it a bit rich in mid range (high speeed needle) -so that it can fully unload at WOT.
As for the CAP-- some were simply heavy in the rear end -- If you can balance the model without ballast - it will be about 16 lbs . If you are really careful and luck to have a light wood model -you may see mid 15 lbs.
The model does fly very well and is a real beauty.
It is simply dicey when power is pulled way back and you are doing low speed high angle of attack stuff.
The engine is the zdz 40 RV-L so I presume it's the better one. He said it was purchased about 8 months ago.
Dick Hanson:
When you say open muffler do you have any models in mind that would work with the ZDZ40. I hear people talk about the canister mufflers but how would they fit on the plane compared to the bisson for instance ?
Well so far the response is do the 50cc engine versus the 40cc.
Dick Hanson:
My Feedback: (27)
I seen several ZDZ 60 to much over kill and I seen a ZDZ 40 plenty, so I ordered the plane and put my ZDZ-40 perfict. it depend on the person.I know this guy tell every body evey thing. but yet to put one back on three weels.
I made a good linkage to my choke very easy.
