Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Engine for 1/3 scale Lanier Laser?
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 04-21-2004, 02:19 PM
Razorback58
My Feedback: (8)
Default Engine for 1/3 scale Lanier Laser?
I have a 1/3 scale Lanier Laser that I've been flying for a few years with a G62. I'd like to pep it up a little bit with a bigger engine, and was considering a Brison 4.2. I'm looking to do some 3D with it, so I'd like to bump the horsepower up a few notches. Is the 4.2 going to be big enough to make enough difference to make it worth the swap?
Old 04-21-2004, 02:22 PM
XpastywhiteboyX
XpastywhiteboyX's Avatar
Default RE: Engine for 1/3 scale Lanier Laser?
zdz 80!
Old 04-21-2004, 04:22 PM
NeoGenesis
My Feedback: (27)
NeoGenesis's Avatar
You could try getting rid of the stock ignition and replace it with a electronic unit. You won't lose much weight......but it will start easier, idle smoother, and it should even pick up a few hundred RPM's. A friend of mine just did that to his, it didn't make the power ballistic, but it does have unlimited verticle now. It also only costs arount $100. Just an idea,
Neo
