If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 23 of 23
  1. #1
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    CA 27% extra 300L Weight with DA50???
    I am almost done building my CA27% extra 300L. I am using a DA50 for power. I weighed the plane yesterday and its tipping the scale at around 15.4 lbs dry. This is without the fuselage covered as yet. I think once I am ready to go, the dry weight may be around 16lbs. I am using 2 1600 ma nimh rx batteries, and 1 1400 ma nicd ign battery. All servos are top end JR digitals (read 8411). Am I still good for 3d flight? I was always aiming for 14lbs dry. Its surprising as this is the weight with graphtech CF main and tail gears. Let me tell you, those are NOT LIGHT. I guess same weight as the stock aluminium gears, only taller. What weight did others end up with a similar setup? Will the DA 50 propel 16lbs plane out of a hover fast enough? ALso whats the best prop size for this setup. I have a 22x10 menz and a 24x8 menz.
    Anurag
  2. #2
    Join Date
    Aug 2002
    sunnyvale, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: CA 27% extra 300L Weight with DA50???
    Well, i think the nicd battery isnt helping. Mine is 14.5 lbs with a ZDZ 50 and a smoke system. I have nimh batteries and all 8411s. I did lighten the tail a bit by drilling lightening holes in the control surfaces. You may want to go to only one receiver pack. I run one 2700 mah nimh, and it works just fine.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	126355   Click image for larger version.
    www.3dbatix.com
    www.desertaircraft.com
    www.planesplus.com
    www.smart-fly.com
    www.fromeco.org
    www.rcshowcase.com
  3. #3
    Join Date
    Mar 2002
    Springfield, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOWSWER!! Ragz,
    I really don't know what is going on here! We built one of this, (over a year ago), and the All-Up-Weight, RTF Dry with a ZDZ-50, and JR-8411's all around was 13.5 lbs!
    I don't remeber doing anything to the kit other than building it. As you are well aware the instructions sucked, so we just opened the box and built the plane the way it appeared to go together. It was, (I only say was because we sold it, it is still flying), a teriffic flyer, extremely stable in high alpha, and unlimited vertical with the little ZDZ.
    We used all the "stock" components, i.e. Landing Gear, Wing tube, etc.
    Here she is when we owned it:
ID:	126490   Click image for larger version.
ID:	126491   Click image for larger version.
    AMA#4939
    Puckett Model Aviation
  4. #4
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Spuck, Thats exactly what I did. Just built the thing with CA glue all around except firewall etc. No extra wood used anywhere else. I hope my scale is messed up. I will weigh it again on a different scale now.
    Anurag
  5. #5
    jongurley's Avatar
    Join Date
    Apr 2003
    Goldsboro, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey rags what length standoffs did you use for the DA-50.. and do you have some pictures
    \"Practice, confidence and arrogance makes you a better pilot, few can use these to the best of their ability\" JONGURLEY 3:16
  6. #6
    Join Date
    Feb 2002
    London, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just finishing mine with a DA 50 can't see it being 15 lbs. The framed fuse is very light. I used the da standoffs and shortened the engine box.
  7. #7
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am using stock purple stand offs. I guess they are about 3 inch length. The fuse seems light, but mine is surely 15lbs when fitted with all hardware etc.
    Anurag
  8. #8
    Join Date
    Apr 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone know where I can still pick up one of these? Planes Plus does not carry them anymore. Any info. would be appreciated.
    Thanks, Mike
  9. #9
    Join Date
    Aug 2002
    New Vienna, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aeroworks is now carrying the CA line.
    Did you know writing in ALL CAPS is considered shouting?
  10. #10
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    how much throw are you guys getting on the elevator. I have moved the elevator servos downwards in order to accomodate the arms vertically upwards. I am using 1 inch arms and this is not giving me more than 30-35 degrees max. I cant use longer arms as they will touch the stab. If I use the arms vertically downwards, it will come in the path of the pull pull wire. Any suggestions?
    Anurag
  11. #11
    GoeKeli's Avatar
    Join Date
    Aug 2002
    North Hollywood, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone figured out how many square inches that wing has on this 27% model?
    joe
  12. #12
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    With a DA50 14.5 lbs with hitec servo 2000nmh ignition 2500 nimh receiver carbon wing tube, carbon landing gear
  13. #13
    Join Date
    Sep 2005
    Helsinki, FINLAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine CA Models Extra is right at 15lbs 7oz at the moment with DA-50. Im running one 2700mAh receiver battery, cf spinner, prop, landing gears and a wing tube, and a KS 86 V-4 canister.
    With a standard muffler I think it would be something around 15lbs even, but not under it.
    And it just came up to that weight and no way could have 14lbs been possible without taking
    great actions to lighten the airframe as it has nothing extra at the moment (except the canister).
    But it sure has enough power at 15lbs 7oz though, but a light airframe is always a light airframe.
    [8D]
    Regards
    Olli
  14. #14
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    wich servos you use
    me 5625 elevator
    5645 ailerons
    5955 rudder
    I have switched 4200nimh sub C to 2500 size A on receiver and 2500nimh size A to 2000nimh size AA on the ignition
    with this set-up I loss 10onces 15.2 onces to 14.8 onces
  15. #15
    Join Date
    Feb 2005
    Tulua, COLOMBIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [img][/img]
    Mine is 14.5 Lbs with CF wing tube and landing gear, DA 50 with standard muffler, and 3 1400 mah packs. Wing area if I did it right was a little bit under 1200 Sq-in.
    The CF landing gear (graphtech) weighs around 3.5 Oz more than the standard one which sucks by the way, and wonΒ΄t have enough prop clearance.
    I use the standard DA stands off which I think are around 2-1/4 inches. I did shorten the engine box to use them.
    Andres
  16. #16
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can you able to fly a decent 3D with thi weight 14.5 lbs[img][/img]
ID:	639197   Click image for larger version.
  17. #17
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can you tell me your complete set-up ?
  18. #18
    Join Date
    Feb 2002
    Redmond, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, it does very well at 14.5lbs.
    My setup is tauruus 52, 5955 on Rudder, 5945s on the rest. Two NoBS 6V NIMH packs for receiver and a 1950 4.8V pack on the ignition.
    Azhar
    www.aztechaeromodels.com
    www.spotonrcusa.com
  19. #19
    Join Date
    Nov 2003
    Billings, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tigil
    Nice plane man. I believe mine will come in at 13.5lbs. Here's mine. Kinda the same sceme.
ID:	641563   Click image for larger version.
ID:	641564   Click image for larger version.
  20. #20
    Join Date
    Feb 2002
    Redmond, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is that a 20x8 prop on the DA? If so, it is too small. 22x8 for break in and 23x8 after that. I am currently running 23A Vess prop.
    Azhar
    www.spotonrcusa.com
  21. #21
    Join Date
    Nov 2003
    Billings, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No. That's a Venom 45cc and yes the 20-8 is too small. I've got a 22-8 and a 21-8 on the way.
  22. #22
    Join Date
    Feb 2002
    Redmond, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the V45. Watch for my numbers on these props: Xoar 22x8, Mejlik 22x8, Vess 22A and Biela 21x10 (3-blade).
    Azhar
    www.spotonrcusa.com
  23. #23
    Join Date
    Nov 2003
    Billings, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool. I'll be posting numbers for the Mejzlik 20-8, 21-8, 22-8, 22-10, and a 3 blade 21-10.5N. Right now I've only got a tank thru it. But sat., weather permitting, I'll be flying it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
