NEED HELP-AVIOMAC 85
LA,
PUT IT IN THE GROUNG PRETTY HARD. TOOK ENGINE APART TO CHECK CRANK.2.5 THOUSANDTHS OUT.NOT BAD? MY REAL PROBLEM IS WHEN I TOOK THE MAGNET OFF THE CRANK FOR THE MAGNETO, I THOUGHT IT WAS ON A KEYED SHAFT. ONLY THE ROUND MAGNET HAS A KEYWAY.ANY ONE KNOW HOW TO SET THE TIMING OR WHERE I CAN SEND IT TO HAVE FIXED IN THE GOOD OLE U.S.A.? [email protected]
