Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Gas engine stand off mounts??
Reply
Old 07-10-2002, 01:00 AM
Terry Reeves
My Feedback: (171)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gas engine stand off mounts??
What is the best way to mount an engine using "stand offs" and what type material is best for the "stand offs"?? Plan on putting either my 3w75,or 78 in a Lanier Staudacher, and either engine requires about 3" from spinner backplate to the engine backplate.
Also, anybody have experience with this plane needing nose/tail weight for either of these engines?? Thanks much for your help.
Terry
Terry Reeves is offline
Old 07-10-2002, 01:02 AM
Terry Reeves
My Feedback: (171)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, I meant an ADDITIONAL 3" needed to fill the stand off void.
Thanks again!!
Terry
Old 07-10-2002, 02:18 AM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check these out.
http://www.geocities.com/traviscouch/extra2.html
http://www.geocities.com/roger_forgues/engstandoff.html
Forgues Research is offline
Old 07-10-2002, 03:49 AM
BPKlein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use 1.5" dowel rod from the hardware store. Cut 4 pieces the length you need and then drill the appropriate size hole down the middle for the bolts. You can either glue tham to the firewall or not. Use a fender washer and a lock nut on the back side of the firewall. I stopped using blind "T" nuts on gassers. Too many have failed.
Bryan
BPKlein is offline
Old 07-10-2002, 11:47 AM
Mike Wiz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW,
I have some of Roger's (Aerografix) stand offs. He does exceptionally nice work!
Wiz
Mike Wiz is offline
Old 07-10-2002, 05:38 PM
pukinbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just mounted a 80cc ZDZ with some of Roger's (Aerografix) stand offs....and I also agree - he does nice work!
David Soniat - tampa, fl
pukinbuzzard is offline
Old 07-10-2002, 06:03 PM
cu. in.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default T Nut Failure
Hi KleinBK,
When you say that T nuts failed, was this because the metal threads of the T nut stripped, or because the T nuts pulled thru the wood firewall with the bolts still attached? Or was it something else that caused the failure?
Thank you,
Bruce
cu. in. is offline
Old 07-10-2002, 07:11 PM
epc
My Feedback: (33)
epc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From high grade ply . cut witha hole cutter 12 1" pieces ( 3 for each spacer to get the 3" that you need ) and glue them together with epoxy.
You can glue it to the firewall or use it siply as a spacer.
epc.
epc is offline
Old 07-11-2002, 06:14 AM
BPKlein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cu. in.
If you picture a "T" nut as the letter "T" so that the flat part of the nut is up. The vertical leg seperated from the horizontal leg. I have a baggie full of broken ones in all sizes that I have collected over the years just to show people not to use "T" nuts in a high vibration enviroment. The last ones I added to my collection are from a 3W-100 that departed the front of the plane in flight. The back side of all 4 "T" nuts were still in the firewall, but the threaded shank was still on the bolts.
BPKlein is offline
Old 07-12-2002, 12:17 AM
cu. in.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KleinBK,
Thank you very much. I had never heard of this sort of thing happening and will avoid T-nuts in the future.
Sorry to hear about the 3W100.
Bruce
cu. in. is offline
Old 07-12-2002, 12:33 AM
CrashMeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you need standoffs that are more than 1" long, avoid any kind of straight posts. Torque will induce more vibration than you want.
What I do is to cut strips of 3/16 or 1/4 birch ply (Midwest). Stack the strips two vertical, two horizontal, two vertical, etc... Use CA to join them. This provides rigidity to prevent any twist from the engine but is much lighter than a solid wood standoff.
Difficult to explain, so I popped downstairs and took a picture
CrashMeister is offline
Old 07-12-2002, 12:39 AM
Forgues Research
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Obviously, you have never tried them before. The standoffs on my plane are 3 3/8" long and I have no vibrations. And I have many very satisfied customers to prove it.
They have to be done right and installed right though.
Old 07-12-2002, 12:44 AM
CrashMeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I have tried them. Not yours (which cost a small fortune), but 3/16 wall aluminum tube cut to length, 2.25 inches long. The BME 102 bolts down rigidly, but there is still some torque induced vibration. (The picture shows a BME 50 on a GP Pitts.)
Regards,
Craig.
Old 07-12-2002, 01:01 AM
Forgues Research
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I don't know if you meant mine cost a small fortune, but I have no complaints.
Aluminum tubing as you describe them will not work properly, that's why I machine mine from barstock.
Expensive is quite subjective, you get what pay for.
Old 07-12-2002, 02:24 AM
Terry Reeves
My Feedback: (171)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default mounts
Thanks so much to all for the emails/help-its great to have this kind of support from fellow modellers. Many absolutely great ideas as I build strong first-then worry about weight!! Thanks to all again and God Bless! Regards,
Terry
Old 07-12-2002, 06:30 AM
Giant Scale
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you figure the cost of your time and aggravation to try and manufacture a set of standoffs from dowels..etc, $35.00 is extremely reasonable! Besides if you've got $1500-2000 tied up in an engine, what an extra $35.00??
Roger,when I need a set of standoffs I'll be sure and get a set from you. The quality appears excellent.
Giant Scale is offline
Old 07-12-2002, 10:24 AM
Forgues Research
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you,
I appreciate it.
Old 01-02-2011, 01:00 PM
rcflyinmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gas engine stand off mounts??
Question;  I am building NitroPlanes CMP P-40 War-Hawk 140 73" span, Basic kit 10.75 lbs. Recommended Engine(s) 2stroke. 1.08-1.20, 4stroke. 140. I have not bought the engine yet but its going to be gas. The pre-built plywood engine mount is part of the model's structure and designed for the standard glo fuel engine installation  (no Standoff). I want to build this bird  with retracts and flaps so it will be closer to 14 lbs. RTF. The CPRC-pro 26cc and the Evolution 26GS or maybe the Evolution 40GX[X(] are some of the engines I'm considering because they have glo style mounts. It makes me wonder,  Is the extra vibration of the gas engines the reason most  have standoff's?. Would it be better to modify the structure of the plane and use standoff's? Would the Evo. 40 be too much?[]
rcflyinmike is offline
Old 01-03-2011, 06:44 AM
K-Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 3/4"X3/4" square Birch stock from Lowes. I know it's not the lightest way to do it but it's simple and easy for someone with limited woodworking skills such as myself. It also seems to reduce the twisting effect of large gassers.
K-Bob is offline
Old 01-16-2011, 05:43 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What size bolts are you using to hold the engine to the fireall?
tailskid is offline
