ultimate advice
GA
RE: ultimate advice
DB,
If you get the CG more forward this will stop unless for some reason you have slop in the elevator system allowing the surface to float with changes in angle of attack. Also your thrustline (up or down) can affect this as well. The trick is to have the thrustline pass through the vertical CG as close as possible to avoid any pitching moment changes with power application. If for example your vertical CG is low then you need up thrust or if it is high you'll need down thrust. Smaller diameter prop will help...I like the 10 x4.7 or 11 x 4.7. With the 12x6 prop the prop normal force is probably too much and causes one to have to run the CG farther forward than the recommended CG. I also like to keep the flying weight at or below 11 oz.
George
George
RE: ultimate advice
George
Thank you for your response. I was definatley going to a smaller prop after reading your previous advice. I will now check the vertical CG as well as thrust line. I have found that moving the batt further forward of the strut helps a little.
I will keep working at it , as I love this plane. Most fun i've had in years of flying!
DB
DB
GA
RE: ultimate advice
DB,
Try not to focus on the battery position but rather how much you actually moved the CG of the airplane. Let me know how these modifications work out. I'm glad to hear you're having fun with the model.
George
George
FL
RE: ultimate advice
George,
how do you measure the vertical cg of this plane?
I am in the midst of building mine, and I would like to place all the electronic correctly from the start, rather than adjust alot later.
GA
RE: ultimate advice
To figure out where the vertical CG is located I typically poke a hole in the foam fuselage side right behind the propeller shaft and suspend the model and note the angle that fuselage takes on. I downloaded the Tribute and Ultimate manual and I believe a description for doing this is on page 32.
#31
FL
RE: ultimate advice
I guess I always leave the instructions as a last resort.
I haven't gotten that far in the build, and didn't think such advice would be included.
BTW, why don't you post at the ezone?
#32
GA
RE: ultimate advice
Don't feel bad...I hardly ever read the instructions
I barely have enough time to keep up with the RCU questions. EZONE's certainly a great site for electrics...I wish I could do it all.
George
George
#33
FL
RE: ultimate advice
I only mention it since it seems that there are more posts on the ezone concerning your plane, and definitely more mods posted there.
--the brute
--the brute
#35
RE: ultimate advice
George,
Thanks for the informative reply on motors and their ratings Post and 24. Found thread via search so I'll take the liberty to add some additional to it.
I'm in process of scaling up a Tensor from tracings of friend's plane. Scale 130% ( 35.1" span x 11.05 chord) Material 4mm Coroplast looking at AXI 2820 series motor w/ 40 amp ESC, 3s2p LiIon 1800 mAh
and standard servos. Calculated target wt. 51 oz Wing loading 11 oz /sf Comments welcome, this is my first electric.
Now for my question. Wing incidence, what should they be? I either mistraced or the top wing has about + .65 degree incidence to both fuse slot and bottom wing mount.
#36
RE: ultimate advice
Way too heavy. Standard servos? Everything is way too big. Build a Tensor uder 8 ounces first and then tape a one pound weight at the CG. Maybe 200% with mini servos. It is alot harder than you think to find the perfect setup. But i would reccomend building something else first.
