New to Gas, have questions about exhausts
Hi
I have just brought a Wild Hare 28% Extra 300LX about three weeks ago and I am looking at the idea of using a canister muffler; I will be using a DA50-R for power.
What I would like to know is what canister muffler people are using in this plane with the DA50. I see on the Wild Hare website a MTW td75 used as an example with the MVVS 56.
I was thinking about a KS #83 but would like some feed back on this muffler with respect to fitting inside the fuselage. Is there a website for KS exhausts other than the DA SITE?
I need to know
-what canisters people are using in this plane
-what does the canister weigh with header
-are there any problems with them i.e. vibration, falling apart
-most important will it affect the throttle response or mid range
Any replies would be good.
The reason I want to use a canister is because we have noise restrictions although the club is pretty relaxed on it and also the fact that I have an almost complete 2x2 pattern model with an OS140RX on a seven chamber muffler and the motor is so quiet when running on the test stand, there is more noise from induction than exhaust .
That's my fair share of questions, Thanks Anthony.
I need to know
TX
RE: New to Gas, have questions about exhausts
Go to the wildhare support forum at the top and ask.. Tom, and other guys will let you know... My edge arrives tommorow with a DA-50 soon after so I don't know but they will..
My Feedback: (99)
TX
Do yourself a favor and call up DA. that would be the best source.
OPPS..............Sorry just seen your location. might be cheaper if you send them a e-mail
I know I should of asked in the Wild Hare forum but I'll thought I would get more replies here.
any way I not only need to know about the placement of the canister in the fuse but also
how they run, weight ect, same as what Ben beyer was asking
Anthony
Anthony
TX
Well I just happened to venture out of the wildhare support forum.. I assure you you will get an educated response there..
TX
ORIGINAL: scottfl78
