Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Super Cub Landing Lights
Old 01-31-2005, 05:52 PM
BiplaneCrasher
BiplaneCrasher's Avatar
Default Super Cub Landing Lights
I wrote in previous posts that I ditched my Super Cub on it's maiden flight. I thought of having some fun over the winter, so I striped the old covering off and I am recovering it in my scheme, although not to scale. It is destined to be a tow plane and possibly used for dropping rc parajumpers. I needed to uncover the wings anyhow to inspect the frame for cracks from the wreck. Amazingly there were only a few puncture wounds thru the sheeting.
I used a Ram Landing Lights package with the momentary switch removed, and with a longer lead soldered on in place to fit its way thru the wing into the cabin where the battery will be with an electronic swtch. When its covered you will not see the screws as they will be removed and the clear plasic will be glued in place. This was done just for fun. On the full size plane the landing lights would be under the cowl or almost out to the end of the wing. I would have liked to added a occilating circut to the lghts and mount them under the cowl. I found a phot of this once but can't recover the photo.
ID:	223328   Click image for larger version
ID:	223329   Click image for larger version
ID:	223330   Click image for larger version
Old 01-31-2005, 07:06 PM
CrashBurn69
Default RE: Super Cub Landing Lights
Looks great. Keep the pictures of the new covering coming.
Old 02-03-2005, 06:09 AM
BiplaneCrasher
Here we go, some progress.
ID:	224361   Click image for larger version
Old 05-09-2005, 05:48 PM
stephen thompson
hi,
where did you get the landing lights for your super cub?
steve
