Question on battery backup
TX
I'm rebuilding my Giant Stinger and have recovered the tail and bought a lot of cool little upgrades. I went out and bought 6 futaba 9402 servos which are lightning fast and very powerful, and I bought some awesome carbon fiber pushrods and some very high quality control horns. I've also taken the time to strip the fuselage and add 1/16 ply from the nose back to the end of the wing saddle as I heard that the fuse tends to break at the forward end of the wing saddle. I was going to cut the wing in half to facilitate adding a stronger spar as I've heard that is the weak point, but I decided to just cut 3" off each end of the wing to make it fit in my truck bed, and hopefully the wing just wont break. I also have done a lot of repairing and just general work on it so.......,,,
my question is this. I've heard of devices that allow you to run two batteries, one as the primary and the other as a backup. Can anyone reccomend one to me? I've no idea if this is an available option, but I'd like to be able to have the charger charge both of them without me having to take them out of the aircraft. I'll post some pics when she's all back together but hopefully, someone will have the rigt product for me, I've spent so much rebuilding this monster that I don't want it to go in because of a bad battery.
C.P.
C.P.
My Feedback: (20)
NC
RE: Question on battery backup
Hey CP
Take a look here > http://www.rcbatteryclinic.com/
Click on.....> ( Parallel Operation Reliability and Flight Time) on the left side of Reds web page.
HTH
HTH
My Feedback: (309)
CO
EMS Jomar makes a battery backer.
http://www.emsjomar.com/
Go to reliabilty enhancements and you'll see it there.
I have an extra one of these I'lll sell you at a discount if you're interested. PM or e-mail me.
Jim
Jim
My Feedback: (9)
FL
ORIGINAL: Hammbone
Jim
Jim
There's some words about this in the latest High Flight magazine.
ORIGINAL: branded
This is the only way to correctly implement this scheme. Simply plugging another battery, one that's not isolated from the other, is actually decreasing the reliabilty and robustness of your R/C system.
ORIGINAL: Hammbone
Jim
Jim
Sorry, I guess you struck a nerve.
Jim
IL
My Feedback: (38)
With the EMS Jomar battery backer, you must use 6V cells because the backer itself uses about 1 volt to operate. Therefore, you only get 5 volts to the servo's. I wanted the speed and torque that 6 volts gives you so I returned the backer and went to 2 batteries and 2 switches directly to the receiver. The advantage of the backer is that it can isolate a shorted battery and monitors each cell for even distribution. To bad it reduces the voltage so much.
Paul
Paul
My Feedback: (31)
ORIGINAL: Icebird
If you don't believe me, just hook a 4 cell battery pack to a 5 cell battery pack, with an ammeter in between, and see for yourself what happens.
ORIGINAL: mglavin
Have you actually performmed this test? What specifically were your results? I saw the information in High Flight too, something about 3A alarmed me as my findings in this regard were somewhat different.
ORIGINAL: Icebird
HTH
Jim
