Dively Pitts problem
My Feedback: (204)
Just flew my Dively Pitts today, The Brison 6.4 was more than adequate power. The problem I had was the airplane took off and went into a left bank, I corrected with ail. trim, all was fine until I powered back, then I had a right bank. I haven't looked into it yet but my feelings are a warped wing, the upper left wing leading edge did look like it was pitched down. how about some feedback, any would be appreciated.
Frank A Rega
Frank A Rega
...the upper left wing leading edge did look like it was pitched down.
Set the plane up on a good surface and check these things, and fix whatever discrepancies you find. Your plane will turn from a tiger into a kitty cat and will be a lot more fun to fly.
