SWB control horns
VA
SWB control horns
i have a question before i order my horns.. what size thread is in the SWB horns? is it 4-40. and will the H9 4-40 ball links work? or is there another suggestion with a wb link to what to use with this horn
thanks,
thanks,
My Feedback: (25)
AR
RE: SWB control horns
Also your servos (if you use JR) are 3mm. Replace the stock servo screws with ca-head 3mm x 8mm screws... you won't regret it.
Not sure what the other brands use, but you should still replace them.
