hanger 9 260 engine question
IL
I really want to purchase a hanger 9 extra 260 but need suggestions on an engine. Vertical pull-out of a hover is a MUST!! Will a BME 50cc be sufficient?
thanks,
Brian
thanks,
Brian
RE: hanger 9 260 engine question
Any decent 40 will do it - my 26 on a pipe will do it -not fast but a nice positive vertical
I can't see why anyone goes over 13 lbs on this model mine is 11.5lbs
My Feedback: (52)
My first place engine is some what heavy and mine weighs 15 pounds. It's heavy but still hovers with plenty of power to spare. I bought it used this way. I would have built it lighter myself.
OH
ORIGINAL: dick Hanson
Mr. Hanson,
I have been thinking about this plane for awhile, and I agree totally on the weight that it should be built at. I think it is funny how hard we had to work to get our 72" planes to come out at 12lbs. Now we can build a bigger, lighter plane cheaper and easier. You got to love good wood selections and building practices.
CA
Moki 2.10, around $200 less than DA, pulls hard, hover at just a shade over 1/2. Runs on 0% nitro, starts 1 flip, swings 20x10 at 7400. plane weighs 13.5lbs.
Might try the DP blue head 2.10 same motor, runs on 15%
MO
NEVER try and run the DP Blue head at 15% after months of success with 5% in my DP blue head 210 I re-tuned for 15% and the engine locked-up after 4 minutes of flight.
They will work with more nitro- You may have to raise head a couple of gaskets worth- I like the way they run on more nitro but as with any glo engine --ya gotta match compression with prop load . The Moki or any glow engine responds same way - Rossi- OS/ ST etc.. been ther -- frankly any decent 40ish gasser is a good choice
you can do it at 13 lbs or less.
even a good 35 gasser is fine. cept most are heavy an old BME44 or that type or a Brison etc- something 2.8 lbs
In new engines that would be the ZDZ40 or a Evolution 45 GX or MVVS same engine --
IL
i am just concerned about being able to pull out of a hover with plenty of power. If the evolution 45 will do it i'll go with that.
