Aviation Models 35% Yak Build
#402
My Feedback: (9)
KS
RE: Aviation Models 35% Yak Build
I have just ordered my first gasser and it is this 35% Yak based upon everything I have read. I am getting ready to order my DA 100 with a standard muffler. My question is, do I need any standoffs or anything else to mount the engine? If I need standoffs, what size do I need?
Thanks in advance,
Keith
Thanks in advance,
Keith
#403
Yes you will need standoffs. I think I used 3/4" long on it. That put the prop about an 1 3/8" out from the cowl. You want the prop out away from the cowl or you will lose thrust.
Randy
Randy
#404
AK
Not sure about loseing thrust,,ive got 2 SD Yaks,,35%'s,,i run my prop about 1/2 inch in front of the Cowl with 106'S,,ill race anybody in a vertical pull.i know DA's wont keep up with them,
NdFrSpeed
NdFrSpeed
#406
My Feedback: (21)
torque-up i have a question ? did you do any mods to your motor box ? i see you did`nt use any standoffs on your 3W , i`am in the building stage and also useing tha same 3W and would like to pick your brain for any thing that would help me with this area and any other, cg set up ect.
e-mail pics if you would`nt mind [email protected]
thanks again and look forward for any help.
#407
My Feedback: (16)
TX
I didn't have to use any standoffs... According to Garret, the 35% Yak was designed for the 3W 106... I put the firewall in and bolted on the motor... You do have to trim a bit of the former / brace on the left side of the firewall for clearance with the cylinder... Without standoffs, the prop is about 1 1/2" from the front of the cowl... You will need to build some cowl ducting too for this setup...
I dumped my Yak last Saturday... Low, no airspeed, downwind and the motor coughs & dies... It did a nice face-plant from about 50'... Knocked out the firewall and broke all the formers at the TE of the wing... Already have the fuse fixed and new cowl ordered... Will be putting a BME 115 Extreme on it... Mine was way nose-heavy with the 3W 106... I had to move everything back and still add 6 oz of lead to the tailwheel to get it to balance the way I like it... I'm going to lose 1.5 lbs of nose weight and gain some power with the BME... Also thought about a ZDZ 160...
Here are some pics of the install...
#408
My Feedback: (21)
sorry to here about the misshap but glad its repairable . whats up with the 3w 106 had it been giving you problems staying running? or going thru it`s break in stage? i just traded off my da 100 so i`am forced to go with the 3W/cs 106 . did you have all your gear includeing smoke pump aft of cg and still nose heavy? oh and on the ducting and opening for airflow did you just close off top and bottom of your cowl inlet so the air flow come across the heads? and open the squre at the exaust point. thanks again on your pics and input.
ORIGINAL: Torqued-Up
#409
My Feedback: (16)
TX
ORIGINAL: eagletalon
My smoke pump was in front of the fuel tank in the motor box... The smoke tank was on CG in the pipe tunnel... All batteries at the TE of the wing... Weight on the tailwheel... I must qualify my comments about the airplane being nose heavy... I like my 3D airplanes to be tail heavy...
On the cowl ducting, yes, you need to block air flow into the top & bottom of the cowl opening and build a duct that forces air over the cylinders... There are several threads with examples & photos... Here's one:
http://www.rcuniverse.com/forum/m_55...tm.htm#5510268
#411
My Feedback: (16)
TX
It's so big that I never checked where the CG is in relation to the wing tube... I just put everything where it's supposed to go and flew it... With the batteries at the wing tube, it was way too nose heavy for me... I built a tray that mounted in front of the turtle deck under the canopy and put all the batteries there... It was better, but still not the way I liked it... I started adding weight the the tailwheel bracket until I got it where I liked it... Wound up with 6 oz on the tail... It is noticeably tail heavy, but flies "hands off" inverted...
Something's not quite right with my airframe... Not sure if this applies to everyone else's or not... With my setup, I have probably 6 - 8 clicks of up elevator trim (from neutral) to fly straight & level at half throttle... That's alot of up elevator trim... Inverted, it's hands off... No noticeable climb or descent on inverted 45 degree uplines... The motor is in the airframe straight... That much up elevator trim to fly straight & level indicates that either the CG is way off (nose heavy) or the incidence is off... It's odd, but it doesn't keep me awake at night... The airplane still flies awesome... If (when) I finally toast this one I'm going to get a SD 37.5% Yak in the Russian Thunder scheme...
#412
My Feedback: (20)
PA
Sounds like your stab incidences are off.Not surprisinig, mine are off a little also, not much as to rip apart the tail of the plane to fix, I'll fly it and see how bad it affects it.
#413
My Feedback: (7)
I just finished a 37.5%,flew hands off no trim needed right out of the box.Built a 35% SD Extra 260 for my son,same hands off no trim needed.picking up a 35% this week to install a ZDZ120 with fuse mufflers.Cant wait,like X-Mas in May.
Donnie
Donnie
#414
My Feedback: (21)
Torqued-up sorry to bug you again , just wonering if you had any pics of your exaust cut out and throttle servo placement ? I have all the hinge & servos mounted except the throttle, and set the 106 on it today,
thanks for your help & ideas. let me see if i can post some pics.
#417
VA
I think one would work for just normal flying, but I do not think one will give you enough control for 3D manuvers like knife edge and definitely not knife edge loops.
#418
My Feedback: (7)
LA
Hey: Guys has anyone had a problem with the canopy cracking when trying to cut it. A freind of mine, the first three flight's there three different cracks. I noticed that they are bad about cracking when cutting with laxan sissor's. TomBob[]
#419
My Feedback: (13)
Mine did crack when cutting with scissors. I went ahead and glued it on the frame anyway. So far so good. Only has a few flights on it so far, but no further cracking.
#423
My Feedback: (21)
looking good Jongurley, I`ve just about got every thing complete on mine just going over my final check list and got every thing loktite/blue, looks like i will be good for its madden flite in a couple of days.
let you guys know how things go.
Thanks for all the input from this thread it`s been quite helpful.
#424
My Feedback: (9)
KS
Does anyone have an opinion about the best prop for 3D in this plane with a DA100 once the break-in is done. Curious about which prop will give the best thrust to weight and all around good 3D performance. Just received my plane but have not had a chance to look everything over yet. I'm excited and can't wait to get started.
Thanks in advance,
Keith
Thanks in advance,
Keith
#425
My Feedback: (7)
LA
I have been flying mine with a fuchs 27x10 so far it's the best ,out of a P tip 27x10, and a menz.27x10. This weekend I will try a Vess 27A. I have heard that the Vess as a good prop. I will let you know .
