The BEST Smoke System
#352
My Feedback: (85)
RE: The BEST Smoke System
How would you set up a variable output smoke pump for a JR 10X??? What I want is less smoke fluid at lower RPM's and more smoke fluid at full throttle. I want to mix channel six (flap) to the throttle and use the Mix switch on the upper right hand corner to turn the smoke pump on and off...
Thanks!!! Kevin
Thanks!!! Kevin
#353
My Feedback: (14)
ORIGINAL: Kevin Greene
Thanks!!! Kevin
Thanks!!! Kevin
http://www.rcaerobats.net/GPTips/SMOKE/SMOKE_JR10X.htm
#354
I have found that pete tindal's smoke systems are good just put one on my edge 540 with a saito 1.25fa great smoke will add picture soon.
#355
My Feedback: (33)
Any comments on the use of a 50/50 mix of diesel and kerosene for smoke oil?
I have some not-to-old diesel and Kerosene that I would like to discard or try as smoke oil.
#358
I put some super-dri through the GCMS and it contained med chain hydrocarbon mix just like it sez on its MSDS. Parrafin has a VERY similar composition. I have gone away from smoke but would like to try lard with a little a little hexane to liquefy it.
The problem with kero, diesel etc is they contain too many benzene containing molecules which dont burn too well, hence the slime.
