H9 Ultimate 46% questions
My Feedback: (190)
I am statring a H9 Ultimate. I would like to use one servo per aileron. How has this worked for anyone that has use one servo? Are there any weak areas thar need attention? I would also appreciate any pointers. Thanks in advance Andy
My Feedback: (12)
WA
RE: H9 Ultimate 46% questions
No issues here with 1 servo per. M McConville uses 1 per for some time now. there are several threads that have people flying with them. just use the inner servo bay and use top notch hardware and you be fine. i run 5 cells at 6volts for mine.
My Feedback: (38)
Welcome to the Big Bipe Club. Just finished mine a couple months ago. I went with the simple method.
2 JR rx's
2 JR 3000 mah nicad- yes nicad
1 9.6v nicad (turbine ecu pack) for rudder
1 JR 2400 nicad for ign
all batts are 4 cell except the 9.6 of course
all hd JR switches
1 8611a ea ail
1 8611a ea elev
one seiko 50 on rudder
With two rx's, I cross controlled everything. And I had plenty of ports to plug everything in. No matchboxes, powerbusses or any of that stuff. Not even a y harness. Only needed one mix for the ailerons on an aux channel. This is about as simple as it gets, and it works great. Now , if you're a lipo guy, you may want to go another direction. Me, I wanted reliability, simplicity, and as few failure points as possible.
Mine weighed in at just under 41 pounds, dry. I have now added a smoke system. So it gained a little. The 41 lbs did include the smoke tank and plumbing though.
Some things I did before I started the kit- I went over most of the joints that I could reach with BVM areopoxy. This being an ARF, you know why. I pinned the firewall with carbon fiber dowels. Most the servo bays needed extra plywood, especially the elevators.
Just to qualify all this, this is my first giant. I may have done this all wrong. But, like you, I asked alot of questions and made my own decisions. If I can help many further, don't hesitate to ask.
Randy
2 JR rx's
all hd JR switches
1 8611a ea ail
1 8611a ea elev
Randy
My Feedback: (18)
GA
Just finished mine last week, First Flight last Saturday. LOVE IT ! 3W 157 Comp with cans.
I used one servo (JR 8611a) on each aileron and elevator, used 2 8611a's for rudder.I have not experienced any problems with this set up. and ask any one that knows me I ring an airplane out! I ran four gallong through it Saturday and Sunday, If anything was going to brake it would have Sunday.
I set my CG at close to 10" but I like a tail heavy plane. It is a monster on 3D rates and flies like a trainer on low rates. You will love it.
Good Luck and Happy Flying.
Wayne
Wayne
Hi Guys. Not sure if this is the right palce to ask but i am looking for a second giant scale model and i want a Bi Plane. I have a composite extra on a DA50 and would like either a 50CC or 100CC DA driven bi plane as my next model. ARFT is preferabel as i have limited time outside of work. I think the ultimate is a little large for the filed and my car (i live in the UK) and was wondering if there were other great models out there that you guys were aware of.
my ulti is 1 and a half years old - best show plane out there
i run
2 x hi tec 5945 per aileron
1 x hi tec 5955 per elevator
1 x seiko in rudder
1 x hi tec 5645 throttl
1 x powerbox champion
1 x sullivan smoke pump
2 x 5600 TBM li on - powerbox/servos/receiver
1 x 2800 TBM li ion - ignition
1 x 2800 TBM li ion - rudder servo
1 x 1200 lipo - smoke
DA 150 - bolly wood 32x10
pete CF spinner
i run
1 x seiko in rudder
pete CF spinner
