Hitec rx's in 33-35% planes
LA
Is anyone using a Hitec rx in a 33-35% plane.I put a Hitec Supeme 8ch rx in my 33% AW Edge 540T when I had trouble with my brand new Futaba PCM rx at the field.I am running 8 JR 8411's,one JR DS811,2 JR Matchboxes,2 1650 mah nimh batteries,and an Electrodynamics fiber optic ignition kill system.Needless to say I have every reciever port used,and some on y-harnesses.I have 6 flights on the plane so far.I guess I am concerned because when I first started in the hobby,Hitec was pretty low dollar stuff,and not that dependable,I know times have changed and I have lots of Hitec RX's and servos in other planes.Because I believe you get what you pay for,I am concerned about running all that stuff through a Hitec RX.Thanks for the help,
Mike.
Mike.
I have two Supreme 8's, one in a H9 33% CAP (41 flights) and one in a 33% Extra (over 60 flights). No problems at all. The CAP has Hitec servos, the Extra has JR8411's, Multiplex Profi's and Multiplex Jumbo.
Transmitter is a Futaba 9C.
Craig.
Craig.
TX
We use the Hitec supreme in everything from profiles to 40% with no problems. At the field I mainly fly at, the fix when someone has receiver problems is to get a Hitec supreme.
Tracy Hill
Tracy Hill
