Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Midwest Extra 300xs
Old 01-21-2003, 12:50 PM
Mendes
Mendes's Avatar
Default Midwest Extra 300xs
Originally posted by jasonc1354
Are you happy with your wheel pants and cowling? I haven't ordered mine yet.----still looking------who did you buy yours from?
Aeroglass! They are made in Canada. They are the best cowls and wheel pants around. I can't remember who distrubutes them in the U.S.
Stan's is OK but Aeroglass is better.
Old 01-21-2003, 01:27 PM
rhakkenberg
Aeroglass
Old 03-28-2003, 11:39 PM
jasonc1354
My Feedback: (7)
Finally, after messing around with some other ARFs, I got this baby covered and the engine on. I tinted the canopy with RIT dye and it came out perfect. Need to know if any one put a smoke system in their plane. I have the slimline show-time smoke pump but haven't decided if its going in this one. There is plenty of room for a smoke tank but I am not sure how to mount one inside.
Old 03-29-2003, 12:20 AM
rhakkenberg
Default Smoke
Jason,
Can you explain what you mean by the side of the plane for mounting? You should try to get the smoke system on the c.g. if possible. This way you don't change the c.g. With a full tank of smoke fuel. The coolest systems I have seen are removable.
Lets see some pictures.
Rich
Old 03-29-2003, 02:36 AM
Flyfalcons
Flyfalcons's Avatar
I thought about putting a system in mine, but it is heavy enough as it is and I wouldn't want to compromise the wing loading. I do think that if you build it very light then it would handle a smoke system very well.
Old 04-12-2003, 11:03 PM
  #31
erling
Default midwest extra 300s
Her is mine it only has the G38 i wood like to haw 45-50
Old 04-13-2003, 01:44 AM
  #32
Michael Beckman
Default aileron mounts
Did onyone change the mounting of the servos in the wings??? Seems that they are a little light in the wood area for the servo
Michael
Old 04-13-2003, 02:45 AM
  #33
Flyfalcons
Flyfalcons's Avatar
Mine have been holding up well. If you're uncomfortable with the setup you could add some triangle stock between the mounts and ribs.
Old 04-13-2003, 11:11 AM
  #34
rhakkenberg
Default extra300xs
Erling , very nice looking plane. You didn't tell us how it flew.
What is the weight w/G38?
Michael,
Triangles cut from lite ply can be glued to support the sevo tray. Make the length of side A the length of the tray. Side B will be the lenght from the tray to almost the rib top. IThis will give you the abilty to support the whole tray and avoid any "tray torque" from a high pwr, high speed servos. I hope I have explained it well. You can picture a shelve turned upside down with light ply triangles, make them as big as you can. The weight is nothing.
Rich
File Type: bmp
Old 04-13-2003, 02:48 PM
  #35
DGrant
DGrant's Avatar
I added some gussets to the aileron servo trays too, it only made sense, and it really shored the trays up. Just cut some triangles to fit to the tray/rib in an area that wont interfere with anything else, and epoxy them in. I did use epoxy for the trays, as you dont know what kind of torque those trays really recieve, running a 100+oz servo in there I would imagine the trays do get there share of stress.
Remember, the chain is only as strong as the weakest link.
Here's a pic of my Midwest Extra/BME50...
Old 04-13-2003, 03:34 PM
  #36
erling
It flies where wheal but not enough power to hower ,It is 8kg.I bot it like it is w/o servos only 400$
