fuel tank..46%ultimate
building a hanger nine 46% ultimate with a 3w 200titc..need info on placement of tank and 4 batteries in referance to the c.g.
RE: fuel tank..46%ultimate
i installed a 3w 2oo,,insted of the recomended da 150,it weighs 10.52lbs.which engine do yu use.and did you add any weight to ballance it ?
My Feedback: (38)
I used a DA 150. I mounted 2 50 oz tanks, 1 smoke- 1 fuel, just under the cabane struts. Tanks are side by side. I have 2- 3000 mah 4 cell packs strapped to the front former in the canopy area. A 2400 mah 4 cell ign pack in cowl area, and 1400 mah 8 cell pack for rudder about midway of the canopy area. All my pack are ni cads. Alot of room to move things around to get the cg right. I have no other weight added anywhere.
A 200 will be crazy power! That's a couple pounds more. You may get away without adding weight if you put everything toward the back of the canopy area.
My Feedback: (7)
I build one with a DA 150 the cg came perfect per the manual but that cg is way foward
also put the tanks (32oz smoke 50oz fuel) side by side under the cabine struts
