Extreme Flight 88" Yak - Build and Fly
#501
My Feedback: (51)
RE: Extreme Flight 88" Yak - Build and Fly
Well you are in a BIG desert area... Most of te black is on the bottom though and that which is on the wing is mostly over solid sheeting (over the leading edge)
Will black be visable or wrinlkes be visable flying? Yes and No..
#502
My Feedback: (63)
ORIGINAL: Maudib
#503
Either earlier in this thread or in the manual Chris gives instruction on how to keep the black from wrinkling. When landing my Chimpmunk, with a dark blue leading edge on the wing, I was always supprised at how it would disapear when it dropped below the top of the hills in the background when comming at me, especially on landing. Black & yellow are my favorite colors but I orderd a red one because of the black on the leading edge.
Check post 441 on page 18.
#504
Thinking about one of those snazzy stretch covers like the pros use at the big meets? Anyone know where to get one of those to fit the 88" Yak?
#505
My Feedback: (51)
Actually... the one that comes witht eh 88" is probably better... with it's reflective coating... it'll reflect the heat better than perhaps even a white cover will...
#506
I'm talking about the stretch fabric covers that cover the whole airplane, spinner to tail, wingtip to wingtip. I saw them at the Don Lowe Masters on airplanes in between flights. Looked liked they slipped on and off very easily. Where to get them?
#507
My Feedback: (24)
ORIGINAL: EAGLE PILOT
#509
TN
I'm sure she can find one to fit.
#512
My Feedback: (37)
NC
#513
Thanks for your replies, I think I'm going to stick with the Y/B version...I've just been checking the videos and most of the black is on the bottom so as some of you guys mentioned it shouldn"t be a problem.
So we get a canopy cover with the kit ....way cool !!!
#514
Thanks AHPowelson! Those Plane Wrapper covers are just what I was looking for to keep my Ultra-Cote looking nice! Like the big variety of colors!
#515
My Feedback: (51)
Great... just what we need... bodybags for our planes... Tee hee...
They look neat...
Hey guys... have you seen my plane? I left it right here and....
They look neat...
#519
My Feedback: (17)
KY
it will be 1 pound heavier plus what ever the bigger prop weighs than the da50 and have great power to weight.
I would prob use a 3 blade to tame down the power a smidgen
the engine price diff is very close.
go for it if you have the desire to do it.
#520
GA
Finally flew the Brillelli 366GT powered Yak today! Awesome! 7180 on a 23x8 Mejzlick on the 2nd tank of gas. I could easily see this thing turning 7400 after break in and tuning. Power is awesome and super smooth and quiet with the ES CF pipe. 4 flights today, hopefully several more in the morning before work so we can get some video. So far I really like this engine!
#522
My Feedback: (42)
ORIGINAL: EXTREME FLIGHT
#523
My Feedback: (31)
NC
EXTREME FLIGHT
can you feel those extra CC on the being broken in motor?
have u tired the vess props i just read about them today i hear the 23a is the one to have. i have no idea about a lot as i have been out of the loop for a year or so.
#524
TN
ORIGINAL: krayzc-RCU
EXTREME FLIGHT
EXTREME FLIGHT
#525
GA
Tyically same as a non piped set up to start with. Lawnboy ashless at 32:1. Max out rpms then back off about 300. Will run 4 gallons making small needle valve adjustments as needed. After this will switch to synthetic and re-set needles. That's it. You can probably cut the header and gain a few additional rpms on the top end, but may start to sacrifice midrange smoothness and transition. I typically don't cut the stock length of the MTW header. I was really impressed with the transition right out of the gate with this set-up. No stumbling to come up on power.
