Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 88" Yak - Build and Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 03-23-2007, 09:57 PM
  #1301
Rockyaged
Default RE: Extreme Flight 88" Yak - Build and Fly
I have received my B/Y version of this Yak and have premounted the DA-50
That I intend to fly it with. I used some 3" standoffs I had on hand, as this was
previously stated as being okay. I am not sure I want the motor to be that far
out as to not have enough cowling to attach to the fuselage. Soooo.. for those
of you who also are using the DA-50, did any of you use shorter than 3" standoffs
and where did you get them? Thanks in advance for any assistance.
Gerald
Old 03-23-2007, 10:43 PM
  #1302
thomasf
I just mounted my DA-50 with 2.5" standoffs along with 1/4 inch aircraft ply spacers that I made out of a 1 1/4 hole saw. I have not mounted the cowl yet but when I test fitted the cowl without the 1/4 spacers I think it was about 3/4 of an inch space between the cowl and backplate of spinner with the cowl at recommended 3/4' beyond F1. So I think with the 1/4' spacer I should be about an inch between cowl and prop. You should be able to get the standoffs from DA or Troy built models. I hope this helps.
ORIGINAL: Rockyaged
Gerald
Old 03-23-2007, 11:53 PM
  #1303
Richard D Bahmann aka/Wrongway
My Feedback: (42)
Richard D Bahmann aka/Wrongway's Avatar
Hey guys, I am sunburnt.
I found that my FAUP 1950 on this plane will last for 1 hour and 15 minutes to 6.05 v and my 4 cell 1450 is at 5.1 by then. THe cool part is I pop out the batteries and send in fresh ones for another hour or more as both batteries are under the canopy and come right out with the velcro release.
I spent over a gallon on that plane today....It truly presents and handles about like a 33% plane with short wings.
2 minutes into the maiden one of the automotive hose clamps holding the header and pipe attaches came loose. I could not get the engine to idle low enough to get a landing. After 3 wheel landings the third one stayed on long enough to slow it down for a stop.
I had trials and tribulations with the G-62 and pipe. The Vess 22B would pull 7700 rpm but was way flat in the middle.(it never sang)
The NX-23x8 did pull better but was still flat in the middle. 7000 was tops for that prop, From 1/4 to a 1/2 throttle you are waitng for something to happen, it was not linerar.(it never sang)
Now the Vess 23A...WOW. From 3/8 throttle on it was pinging the pipe. The baffle btw is at 17.5 and the header is a DA 25mm drop question mark. At full power it was a singing hard.
When you punch out, you really punch out with this power. It lunges much more than my DA-50 with 10 gallons and a side dump muffler on another 16 lb plane. Who want to vertical drag race with me? Bring your pink slip[>:]
On the ground we saw 7400 rpm on the Vess 23A and after 5 seconds it was 7350. Now none of the prop caclualtors, ( I like Pe Reivers) can dial in a Vess yet. But if your Mej. 23x8 was turning this RPM you would be getting over 34 pounds of thrust on a plane weighing 17 lb with fuel and that my friends is 2 to one power.
The plane flys great and it presents and feels is just like the Aviation Models 33% Yak, only with more acceleration on the climb. In the air it looks funny as you expect the wings should be longer. But now when I look at the 33% flying it looks funny like the wings are too long.
I took lots of bumps in the grass and the plane has no inclination to nose over what so ever. The AM CF gear looks good on this plane and performs very well.
By the end of the day I was more confortable with the low knife edge passes more so than any previous gasser. My rolling circles with this plane make me actually appear to know what I am doing.
[8D]
Again, thanks to Chris Hinson and Mike Hall for designing such a great plane.
Oh and there has to be one negative. The big G-62 shakes a lot on the ground at idle. I dont know if it was that or what, but the back lip of my canopy cracked after the second flight. The crack was a good inch long starting from the bottom right corner of the canopy where it hangs over the turtle deck. I have it taped for the rest of the day but need to address it.
Richard
Old 03-24-2007, 12:13 AM
  #1304
krayzc-RCU
My Feedback: (31)
rdb127
tks 4 the flight report, sounds like you will be up to 10 gallons very soon on this bird. Yeah that is my kind of bird. I have to go to the post office and sign for something tomorrow hopefully its the header or c/f pipe deal. If the weather is nice i will set what ever part comes in to the side and put sometime on my Radiocraft. talk to you soon
Old 03-24-2007, 12:19 AM
  #1305
Mokken
My Feedback: (63)
Mokken's Avatar
Here are two video clips from today.
First one is the tach reading of the DA-50 on the pipe. She sounds so good..
You can't stream these clips, will have to right click and "Save As"
http://ptcoad.com/documents/efyaktachreading.wmv - Please right click and "Save As"
Second one is of Chris hovering my YAK then punching out of a hover, pretty good if you ask me for a DA-50 and an 18lb bird.
http://ptcoad.com/documents/efyakpunchingout.wmv - Please right click and "Save As"
I'll have more video later this weekend, have some good video of Chris flying with the B60 and one of him doing his 3D magic with mine.
Old 03-24-2007, 12:39 AM
  #1306
krayzc-RCU
My Feedback: (31)
Mokken
good pull off are flyers still worried about that issue of pull out. Heck brison use to have that on their site about planes being unlimted with a Brison 3.2 up to 18lbs so the DA should not even be an conversation deal about that. She look to rocket if you ask me I don't think mine will be that low so i should be alright to[8D][8D][8D]
Old 03-24-2007, 12:47 AM
  #1307
bgold
I'm not going to worry about the DA being to weak any more. Awesome
Old 03-24-2007, 12:56 AM
  #1308
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: krayzc-RCU
Mokken
I just posted that because this build thread has seen so much talk about the plane being too heavy or the DA not being enough power. Sometimes you have to draw a picture for the detractors out there.
Old 03-24-2007, 01:00 AM
  #1309
bgold
Maudib, look in your pm's. I'd like to get some art orderd
  #1310
zoomer199
Do we need to cut out air exit holes in the rear bottom of fuse?
Old 03-24-2007, 01:03 AM
  #1311
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: zoomer199
Rear bottom? You mean for the pipe? I didn't cut out anything but what the manual said to for the pipe and didn't touch my cowl.
Old 03-24-2007, 01:07 AM
  #1312
zoomer199
No not for the pipe. For to air to exit fuse that is inbound from propwash. Often done on small electrics planes to create air flow through fuse so bats and motors get air flow passing over them.
Old 03-24-2007, 01:11 AM
  #1313
Mokken
My Feedback: (63)
Mokken's Avatar
No, you don't need to do that. Only place on the fuse you would cut out would be the pipe tunnel if putting one in, if not, just leave everything as is.
Old 03-24-2007, 01:17 AM
  #1314
zoomer199
Thanks Mokken. I am ready to maiden if the weather ever clears...Ugggghhhhhh!
Old 03-24-2007, 01:52 AM
  #1315
icrashbipes
My Feedback: (18)
88" yaks are sold out till June according to melissa. this is one sweet plane.
Old 03-24-2007, 02:49 AM
  #1316
Railinrob
Yes ! I just got a tracking number. Mine is on the way and man am I excited
Old 03-24-2007, 07:49 AM
  #1317
Maudib
My Feedback: (51)
Maudib's Avatar
hi Bill...
I sent ya a PM response on the 22nd...
I also meant to tell ya that I now have the FiberFinish in...
ORIGINAL: bgold
Old 03-24-2007, 08:32 AM
  #1318
krayzc-RCU
My Feedback: (31)
well my carbon fiber has arrived and I tell you this is some outstanding work on Ed part of making these things, very light and looks so clean and sweet [8D]
Old 03-24-2007, 09:35 AM
  #1319
diamondave
My Feedback: (29)
diamondave's Avatar
chris you have any "demo" ones put together you can bring to tucson with you? i'll buy one from ya [sm=wink_smile.gif], let you fly at the timpa field, thats my new flying site here, its where they hold the shootout in the fall, nicer runway then what i am used to btw, should be lots of fun...heading out now for my 2nd day there, just need another yak in my hanger now!!!!
Old 03-24-2007, 11:38 PM
  #1320
bgold
My Yak is finally all here and... WOW, you could put your whole head inside the cowl, I'm sure a 50cc engine will fit.
I've got boxes from all over and I opened one of the DA boxes, KS 1060 tuned pipe. That thing is big enough to match the Yak. I compared the weight to my bisson wrap around muffler (9.5 oz.) to the pipe (10.3 oz.) . Vess 23A props look neat and the only thing wrong with the DA after my last "landing" ( straight in, in a cow pie infested field) was a slightly out of round prop shaft extension.
Still waiting on CF LG, ti axles, wheels, kill switch, CF spinner and the aluminum header. I picked up some regulaters and switches from Fromco and am using li-po's. A 1320 on the ignition and a couple of 2100's for the rx/servos. 5 - 5955 & 1- 5965 with SWB arms. Hope mine turns out somewhere near rdb's weight.
Old 03-24-2007, 11:42 PM
  #1321
yarom
My Feedback: (82)
yarom's Avatar
Anybody has a good source for 5955s - pack of 5?any deals on SWB arms?
I see prices all over the place right now and it's hard to find the best source...
Thanks.
Old 03-25-2007, 12:20 AM
  #1322
Barry Cazier
My Feedback: (17)
yarom...
AirWild has them for $93 each, any quanity. That's usually amoung the lowest price. Super nice people to work with.
Here's a link
https://www.airwildpilotshop.com/Mor...product&id=188
barry
Old 03-25-2007, 12:33 AM
  #1323
bgold
Extreme Flight $95.00 each, come with a Yak if you order correctly. Arms too, I didn't find any deals on SWB.
Old 03-25-2007, 07:53 AM
  #1324
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Here is where I will be buying my servos from now on...http://www.donalds-hobby.com/PROD/Scripts/default.asp
He will match anyones price and unlike another vendor I had the displeasure to order from, will actually tell you if he has them in stock or not...
Old 03-25-2007, 08:06 AM
  #1325
vfalcon7
Obriens hobby $90.95 plus $6.95 for shipping. Each servo after the first shipping is $1.00. Donalds hobby will match this price $90.95 and I think they will give you free shipping.
