If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 11 of 440 FirstFirst ... 9101112132161111 ... LastLast
Results 251 to 275 of 10976
  1. #251
    Yak Man's Avatar
    Join Date
    Apr 2003
    Oklahoma City, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extreme Flight 88" Yak - Build and Fly
    Headed to the LHS to p/up a steering arm and a few extras, looks like a short piece of nyrod and operate the choke from the front of the cowl. Similar to the original 87" KISS choke. Any idea about the nipples on Scotts' muffler and the plugged one in the back of the crankcase? Smoke?
    \"I started with Nothing and I have most of it left.\"
    Doug - \"Prop-Wash makes Me HOWL!\"
  2. #252
    Josey Wales's Avatar
    Join Date
    Jul 2003
    **, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The plugged one on the backplate is if you want to run smoke..the one on the diaphragm cover plate is if you want to run a static line into the fuse..
    Welcome to NJ...Where fun comes to die.
    Joe
  3. #253
    Join Date
    Jan 2002
    stevens point, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just finished 1/2 my hinges, used pacer hinge glue. Water cleanup, no mixing, no oozing, no babysitting. Never had one fail yet. Super easy and clean.
    Dave, looking at your pictures, I wonder if longer standoffs would be in order.
    just say NO to monkey glue
    John
    If we all think the same, only one of us is necessary
  4. #254
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JR John... you probably are wondering based on prop efficiency?
    I certainly don't think more would hurt if someone wanted to go out another 1/2 or so...
    On the 87" I went out further to make sure balance would not be an issue... but Chris says balance is not an issue here...
    I did think that if someone wanted to do tail mounted servo... that the extra bit of the engine out would help offset that tail weight.
    But I'm going to fly it as it is.
    On the Brillelli 60... the plug cap is JUST touching the cowl... will epoxy a 1/8" pad of neoprene under it to prevent rattle and not have to make a little hole in the cowl there.
    I can always add 1/2" blocks below the standoffs should I want to try it... but at this point I'm not going to second guess Chris on it...
    But once any of us pay for the plane it's ours.. and we should feel free to do whatever we want to...
  5. #255
    Join Date
    Jan 2002
    stevens point, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave, your right, it's eficency that I'm thinking about. I wonder if the DA 50 sticks any further out? If Da makes 2 3/4 standoffs, I'd probably start with them. Or even 3''
    John
  6. #256
    Yak Man's Avatar
    Join Date
    Apr 2003
    Oklahoma City, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Manual arrived in the mail today, so plane should follow Monday.
    Weighed stock Brillelli muffler 5.4 oz, definitely not the 3.1 oz lite vesion. Might go with the Stock DA muffler to save an oz and only have one exhaust hole thru cowl.
  7. #257
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so the finished product comes in around what weight?
    smooth as silk!
  8. #258
    MustangAce's Avatar
    Join Date
    Aug 2003
    Old Hickory, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What was the total weight Maudib??
  9. #259
    Join Date
    Jul 2004
    san leandro, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Maudib, Could one get away with running 1.25" servoarms on the elevator and ailerons? Thats what I have laying around, I also have a 2.75 staight arm for the rudder. Not enough HUH?
    Trying to get everything needed for the plane so when it shows up (second shippment), I'll be ready.[sm=wink_smile.gif]
  10. #260
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm close but not quite ready to weigh.... later today for sure...
    Thomas,
    You COULD get by with 1.25 arms... just won't get all the throw... but quite a bit... in the long run you'd want to replace them out with th 1.5" though...
    You pretty much HAVE to have the 4" offset arm to get proper gemotery and no slack in the cables... or fabricate one...
  11. #261
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Choke rod:
    a segment of 2/56 all-thread
    cut about 3/8" off the end of a 2/56 balllink
    a segment of shrink tube
    a plastic clevis
    a grommet from Lowe's
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	628732   Click image for larger version.
ID:	628733   Click image for larger version.
  12. #262
    Join Date
    Apr 2004
    GALLIANO, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As soon as I get some time tonite or tommorrow I'm going to mount this new 366GT that my favorite mail-lady just delivered! Man, this motor is a really nice piece of work! I appreciate when people like Scott and Chris take such pride in their work.
    About a week ago I e-mailed Karl Mueller at Mueller Custom headers about him making an aluminum header for the 366GT. He has made one for the Brillelli 25cc but not the 60. His work can be viewed thru AeroBob's site. The price for Karl's header is $48.00 plus $8.00S&H. The aluminum header will be lighter than SS. I don't know how much. Karl can be contacted at kgamueller@rogers.com and all he needs are all pertinent dimensions: Exhaust flange, radius, drop and motor thrust angles and he can get started. If anyone is interested please PM me and "we" can take these measurements and agree that they are correct before sending them to Karl. Thanks, Nico
  13. #263
    Join Date
    Apr 2005
    Seville, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maudib, first of all THANKS for this GREAT build thread !!!!
    Was wondering if your Ignition battery is a 4 cell AA pack..
  14. #264
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank... and you are welcome...
    It's a 4 cell AAA 730 nimh... 1.9 oz
    Made from Sanyo 4H-730AAA cells... Maxx Products has them (out of stock right now)
    When the next gen Roy Sholl's come out they will accept a 2 cell lipo/lion... and I may switch to a 2 cell lion/lipo
  15. #265
    Join Date
    Jul 2004
    san leandro, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Maudib, Making my list for Troy Built. I to would like to get the motor out farther then what you have pictured. I'm going to use a DA 50. I wonder what the gap is like with the 2.5 standoffs?
  16. #266
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yehaw!!!!!! Wahoooooooo! OH YEAH BABY!!!!!!!!!
    I just put it all together, dropped a 4800 lion pack in there, the spinner cone (CF) and the throttle servo... BUT forgot the 4.1 oz DA stock muffler and the SmartFLy Reg with failsafe switch...
    16.5 lbs!
    Add the 4.1 oz for muffler, 1 oz for the reg and switch and 1 oz for velcro mounting the battery and throttle linkage and I got myself a 16.9 lb bird!!!!!!
    Just about what I was expecting with 10.38 out of box.
    I can't TELL you how excited I am with that weight... a DA50 and stock muffler will end up a tad over 16.5 lbs!
    Both of which are gonna be AWESOME power to weight....
    Again, I build light, and am choosey with what I put in... But I shared ALL my build... techniques and items selected... nothing anal here.
    So Chris' 18.5 lbs is well... let's just say on the TOP end...
    Remember mine does NOT have the spats, gear fairings or faux louvers... and I used 3.5" foam wheels (1.9 oz I think it was)...
    I am SOOOOO pumped.
    If you were to use that 6.5 oz gear JR John has brought to our attention, a 2 cell 2100 lipo on the receiver, DA50 with stock muffler and maybe went with the titanium axles... you'd be at 15.75 lbs DRY....
    ANd olny a hair over 16 lbs witht he Brillelli 60.......
    WoooooooooHoooooooo!!!!!
  17. #267
    Join Date
    Jan 2002
    stevens point, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: thomasf
    I'm with you on that one.
    john
  18. #268
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same distance... the 60 and 50 are the same distance with stock standoffs...
    I'd go ahead and get the 3" standoffs... it won't hurt a thing.
  19. #269
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    excellent wieght!!!!!!!!
  20. #270
    Join Date
    Aug 2002
    Roy, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Amazing weight for this size airplane. Looking at pics the fuse looks almost as long as my qq102. Looks like the items you left off are around 5oz or so, does that sound right? Getting real excited to put this one together.
    \"The sky is not the limit, the ground is.\"
  21. #271
    Absolut Yak's Avatar
    Join Date
    Feb 2003
    Trenton, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm going to hijack the thread for a moment, but you guys have more info than anyone I can think of. I did post on the gas engine forum. How many turns do I need on my high and low speed needles on my DA 50? I'm really having problems starting mine. I was going to do a thrust measurement today at the field so I could decide to use the DA 50 with Vess 23A on the new Yak or go with the Brillelli.
    Doug
    N67TP
  22. #272
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    STart at 1.5 turns out on BOTH... that should get you started...
    Is the engine in a plane? Newly plumbed? Sometimes it can be a bear to initally get fuel to the carb... especially if the run is long...
  23. #273
    Join Date
    Apr 2004
    GALLIANO, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congrads Maudib! And thanks for all the tips and ideas. I don't get to build many airplanes so I am going to take my time and really enjoy building this one!
  24. #274
    TailTouch's Avatar
    Join Date
    Jan 2002
    Windermere, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    16.9 lbs !!!
    Man that is heavy...very heavy for bird that almost presents like a 33% bird.
    Will this have enough vertical ?
    I can already see the plane losing speed in a vertical pullout because of the drag...
    I don't know what's wrong with you EF fan club...
    Yak Hole
  25. #275
    cadconversions's Avatar
    Join Date
    Jan 2004
    Scottsville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TailTouch
    16.9 lbs !!!
    I'm glad you put all of the smiley's on there or someone would have about killed ya over tha comment... [:-]
    Kevin
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
