Extreme Flight 88" Yak - Build and Fly
#5051
CA
RE: Extreme Flight 88" Yak - Build and Fly
From trying to fly a GP giant udo with this engine. Now that is one fragile bird. The thick ones in the back are from conveyor belting. The front are mudflaps.
#5052
NJ
Does the motor shake more with the rubber mounts? Ive seen lot of engines with other type of dampers and they shook like crazy.. I also thought that twins shake less then singles.
I know that slimline wont warrenty their mufflers if used on a soft mounted motor.. Something about the muffler can't keep up with the motor shake and will eventually rip the muffler from the bolts.
Just wondering. If it works for you then it's perfect..
Cya..
X
Cya..
X
#5053
CA
I had it in a GP ulti and there was no shaking. 0 vibes at above idle. It would shake if the idle got too low. Ridiculous power in either plane. Mucho excited about how this plane will cary it's weight. However the Ulti flew lighter with this engine than it does with a 50cc ZDZ. Should get to fly it this weekend and I'll post weight and prop speeds with this airframe.
#5054
I just noticed too altavillan that your fueler is mounted on the silver trim line. I mounted mine 1.5" below that c/l line.
Gee, and don't ask why!?
Josey (yours looks to be close to where mine is) and Xtraflyr- where is your fueler in relation to the silver trim line?
Something tells me mine will be the lowest!
#5055
anyone know the size of the allen key used on the collars and the tail connector on the tail wheel assembly?
I've tried 1/16 5/64 and 1.5 and 2mm but none fit!
J
J
#5057
NJ
ORIGINAL: Jaguar Bone
#5058
ORIGINAL: xtraflyr
Mine is located about the same place as you and Josey. Its about even with the leading edge of the wing.. Mine does come back out,have to pinch it. But I also can take the line out like a regular dot and hold it above the tank. I left it pretty long so I can do that..
#5059
NJ
Well that would be the issue I have to work around- nothing to pinch off with this design fueler. I'll know tomorrow as I will do a test fill tomorrow- Man, lovin this long weekend!
ORIGINAL: xtraflyr
Cya.
X
#5060
ORIGINAL: xtraflyr
A long weekend for some.. Im on call this weekend for work. I was lucky so far only 1 call for a bad circulating pump.. If all goes well Im gonna sneak out for some flights tomarrow morning. Supposed to be 47deg.out tomarrow.. Man this weather sucks..
Cya.
X
ORIGINAL: xtraflyr
Cya.
X
A frigid day at the airfield is better than a warm day at the office!
#5062
NJ
We lucked out last year.. I remember flyin January 1st with just Tshirts and jeans. You Florida boys are lucky this time of year. I was out there during the summer..WOW it was dang HOTT!! Ok enough before I get yelled at for distracting the Thread..
Cya..
Frank
Cya..
Frank
#5063
FL
Awesome Day of flyin!. Flying Skunks, Lil Stinker, Lou2, Snoopy3D, Ultrasport, 'Robert' (we need to work on your handle dude!), & VooDoo2 all came out and hucked-it -up! We had three EF 88" Yaks and one EF 74" gasser, out there today! great time by all. Thanks guys for coming over, OH YEAH![sm=thumbup.gif]
#5065
GA
Here is my 88" EF Yak. Mostly built by the book, but I did make a pretty cool carbon fiber baffle for the cowl.
Steps for the carbon fiber sheet...
1. One peice of glass about 2' by 1.5 feet.
2. Use Maguires #8 mold release carnuba wax and wax the entire surface 3 to 4 times and buff
3. I brushed a coat of west epoxy on the glass and let it set for 2 hours (I think this lets all the air bubbles escape and the glue gets a little tacky at this point.
4. I layed the first layer .010 thick and coated it with west epoxy and added the 2nd layer
5. I layed the 3rd and 4th layers and again brushed on west epoxy between layers
6. Let it dry...and dry....and dry...I used slow epoxy which I let cure over night...
7. Cut the circle and trim to fit
8. I used aeropoxy to glue it in place. I also used a bead of silicon glue between the cowl and carbon fiber...this gives some flex...the aeropoxy sandwiches the baffle between the glue and cowl...very sturdy...
#5069
NJ
Hey Yakkers..
You guys with the DA50 on a tuned pipe... Did we ever come to a decision on props, Xoar,Mejzlik,Vess ect.. Size 22x8,23x8? Right now Im using a Mejzlik 22x8 and it pulls it around great, pull out is ok, not outstanding like Chris's prototype in the vids. but not horrible,enough to get you outta trouble.. Plus it's all I have right now..
Cya,Frank
Cya,Frank
#5070
GA
I am using a Mejzlik 23 x 8...pull out is great on the ES Composites pipe. I am temporarily going to switch to the TBM 22 x 8 for break in...then back to the Mejzlik....
#5071
FL
Hey guys,
If you are using the ES Composite pipe or any tuned pipe, the best prop is the VESS 23B. I used to be a hardcore composite prop guy, using the Meijlik and Beila 23-8 props, but when a buddy of mine handed me one to try, I was sold after the first flight. Pulls with authority on the up lines, 3D power is exceptional, and rockets out of a hover like nothing else. I did the same with my 100cc Yak and installed a VESS 27B, Same thing. Its like adding turbo boost with just a prop change.
check out this video from my EF 88" Yak at the last show at Roar & Soar at Fantasy of Flight Aviaiton Museum.
http://www.youtube.com/watch?v=XZyHDgg9JH4
Try it once, and I promise you you will never look at another prop.
#5072
My Feedback: (42)
http://www.youtube.com/watch?v=Apz895e8ERw
http://www.youtube.com/watch?v=jps3cDMJnm4
No matter the power plant. Vess is the best choice. IMO
Plus if you ever meet the guy he is a true to the hobby flying with the guys each weekend where he lives. Kinda like Chris Hinson he is really into the sport. I do't mind paying the extra few dollars on a quality product to support someone like that in the hobby. He is a nice guy too!!
Richard
Richard
#5073
ORIGINAL: Flyin Hawaiian
Hey guys,
Hey guys,
Rennie- That was some GREAT Wirley-Giggin'!!
