If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 308 of 440 FirstFirst ... 208258298306307308309310318358408 ... LastLast
Results 7,676 to 7,700 of 10976
  1. #7676
    Join Date
    Feb 2008
    Buena Vista CO / PCola, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extreme Flight 88" Yak - Build and Fly
    ORIGINAL: Richard D Bahmann aka/Wrongway
    http://www.rcuniverse.com/forum/m_54..._1/key_/tm.htm
    The one flight report was on this exact plane with a 2 cell A123. and on page two I did some other non scientific tests.
    Since I have never lost a battery due to a bad cell or lead I feel that one battery, just like one receiver or transmitter is plenty on this plane. It is all personal choice but you can get well over 100 minutes of flight when set up properly. (BTW I did have a receiver go bad on me and was lucky to get it down in one piece so I am biased)
    Good luck guys, I have been using the 123's for nearly two years and just love them. FWIW when I changed my 40% Edge out from two 5200's on regulators to A123's the flight controls were much much more crisp and worth the while even though my capacity went from 11,400 down to 4,600 available. So I charge after 3-4 flights no problem.
    thanks Richard!
    I haven't read that thread. I should take this discussion there.
    Your 2300 cells have a very different curve.
    Gatorb8
    Phucifino 3D
  2. #7677
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RTK
    The fuel level on the cell pro is close, but not exact. Charge the batteries up and fly a few flights, then re-charge and read how man mah's you put into the battery. That way you know how many flights you can safely fly before dead.
    You are correct. I probably made a poor choice of words with accurate. Close is a better. I always go ahead and let it charge, but I have found that if it says 50% it will usually put close to 1100-1200 mah's back in.
    Charles
    Fly Extreme!
  3. #7678
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I went with 2.4G this season. Next winter I'll probably join ya'll with A123. So far my 1950 FAUP's are work horses.
    Joe AP
  4. #7679
    jnj55024's Avatar
    Join Date
    Jul 2008
    Farmington, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Wrongway, Thanks for the awesome write up on your A123 experience.[sm=wink_smile.gif] I was hesitant to switch away from my trusty Nicd's that I'm used to, but had my LHS order me a couple 2300mah Iron Core Extreme Fromecos to run through one of their Wolverine switches (2 deans in / 1 deans out), unregulated for my EF 88 Yak. I also added a couple of their Weasle Mah counters to put one on each pak so I have an idea of where I'm at at least till I get used to them.
    You have done the homework for the rest of us. Nice Work.
    Sometimes I feel like Yak\'\'n
  5. #7680
    Absolut Yak's Avatar
    Join Date
    Feb 2003
    Trenton, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Richard and Dick Hanson got me on the A123 bandwagon two years ago. They were the first people to really put info out for the rest of us. Until new technology comes out, I'm staying with A123's. Hats off to both of them.
    Doug
    N67TP
  6. #7681
    ORIGINAL: Absolut Yak
    Doug
    Dick Hanson got me started. Hats off to him!!
    I Am WrongWayRC
  7. #7682
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JoeAirPort
    You're pretty nerdy Gator. [8D]
    That's the pot calling the kettle black![8D][sm=thumbs_up.gif]
    Gatorb8
    Phucifino 3D
  8. #7683
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Gatorb8
    Gatorb8
    LOL !!! I thought you'd get it. I'm a nerd and proud of it.
    Joe AP
  9. #7684
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    have a cg question.....
    I assume most of our setups are similar with servos, engines, rx, etc relating to cg balance
    the main cg variable we have is battery weight and placement (although, engines may influence ....)
    I have 3 1100 a123 batts (4oz each) currently on the engine box , A51 (weight?) 3" standoffs
    Inverted flight at half throttle will maintain a 45* upline
    I flys nice but then I try waterfalls, I have trouble getting it around
    When I go to my sim, if I keep moving the cg back, the waterfalls get tighter and tighter
    so today I'm going to start moving the batts back and see how things change
    I would be interested in where others place batts and how heavy they are for comparison
    thx
    Gator
    Phucifino 3D
  10. #7685
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have almost the same setup but a DL-50 with stock exhaust and CF spinner (3 oz). I have a 6.2 oz 5-cell NiMh on the left of the tank and a 3.4 oz 4-cell NiMh on the right side of the tank (there are ply beams to strap the batt's to on each side of the tank). I think it's right at 7" the last time I checked. It's totally neutral at this CG. I usually don't like it so far back but it really flew nice like that...very little work keeping it straight through the rolling maneuvers. These batt's were only temp installed with Velcro and foam padding. You could move at least your rx batts there with little effort to try it out.
    I don't recall the details of my waterfalls the first day out. I'll have to pay attention next time. Do you back off the throttle during the rotation? That's really the proper way to do one per Chris Hinson's advice when this topic came up a while back. I'm not the best at describing the maneuvers but I'm pretty sure you only want throttle on for part of the rotation. You back off throttle once you approach inverted. Then let it fall a bit in sort of an inverted elevator....then roll on the throttle to make it come around again until you approach inverted again...etc etc. Try tweaking the maneuver a little. I just did a few on my sim and I really have to really stay on the ailerons and rudder to keep the wings level throughout the maneuver. It's the hardest one to do right in my opinion. And it's keeping the wings level that's the hard part for me.
    Joe AP
  11. #7686
    Join Date
    Mar 2002
    Randolph, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Me too.It's hard for me to remember which aileron input to give and it goes all wacky.. Chris Hinsons waterfall doesnt look like the waterfall most people do. Looks like he comes over the top and lets it fall inverted,not the continuous spin around the CG. It actually looks prettier I think that way.. But that's just me...
    www.njjf.org
    www.njjf.freeforums.org
    www.myspace.com/xtraflyr
    www.extremeflightrc.com
    www.gsrcrc.com
  12. #7687
    tashley's Avatar
    Join Date
    Apr 2003
    Manvel, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe it's the TruTurn spinner I'm running but it's crazy how y'all are balancing this plane. My c/g is right at seven with my Fromeco pack for ignition on the motor box and two Fromeco packs behind the wing tube for the receiver and servos. All that and I'm using a c/f tuned pipe! Weird!
    Tomakazi
  13. #7688
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Makes sense. The TT spinner and header weigh more than the CF spinner and stock pitts on our Chinese engines. Also your CF pipe weighs very little.
    Joe AP
  14. #7689
    tashley's Avatar
    Join Date
    Apr 2003
    Manvel, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    quote: Also your CF pipe weighs very little. Exactly, it's light weight means it's not contributing much in balancing the model. Just curious, does anyone have a weight on the c/f spinner?
    Tomakazi
  15. #7690
    ArcherIIDriver's Avatar
    Join Date
    Oct 2005
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tashley
    I just checked it for you...my TBM 4" CF spinner weighs 3.0 oz with the backplate, but before making the prop cut-outs. So, it would be safe to say just under 3 oz RTF (minus the center bolt)
  16. #7691
    tashley's Avatar
    Join Date
    Apr 2003
    Manvel, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you Sir.
    Tomakazi
  17. #7692
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine is the 4" Azure hobbies CF spinner and also weighs exactly 3 oz RTF. Comes with cuts in it already.
    Joe AP
  18. #7693
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got 6 flights in today.
    I moved 1 of the a123 4oz 1100 batts from the engine box to just in front of the rudder servo.
    It actually flew much better. It still flys a hands off 45* inverted upline.
    The big difference I noticed was the first waterfall went around quick and straight, much improved,
    The other big difference I noticed was in a (parachute?), I would dive straight down and pull max up elevator, it settled into a nice flat-float down with the tail slightly down, again, much improved!
    I may experiment with the 2nd battery, move it back also.
    The only other thing I can think of is the elevator control horn, I am using the outer hole so I could get more elevator deflection if I go to the inner hole.
    My 3D mentor (Build Fly Crash) says definately go for more elevator throw!
    stay tuned....
    Gatorb8
    Phucifino 3D
  19. #7694
    Join Date
    Feb 2003
    Trenton, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bevel to bevel elevator throw is the only way to go. Makes the plane much more interesting.
    Doug
    N67TP
  20. #7695
    Join Date
    Feb 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe,
    when I do the waterfall on the sim I get it to almost hover, full down elevator, hit 3/4 to full throttle, when it comes around pointing vertical I check orientation and quickly correct with rudder only, I can waterfall it 5-6 times or into the ground, whichever comes first!
    On my Yak, I can get the first one perfect now but on the second one she seems to twist out, I'm not pulsing the throttle though, haven't got that timing right yet. The wind was 10-13 mph, that may have something to do with it? If I pick up the plane in that wind I (and plane) get blown around.....
    One byproduct I noticed about the rear cg was on landing decent in a gusty wind, a gust will give lots of lift and I have to be ready with down elevator. maybe a few clicks of down elev would help for landing
    think I will go bevel to bevel on the elev and see how that flys next, then tweek cg again...
    8 gallons and counting, I'm getting more comfortable with the EF Yak!
    I didn't think about spinners....a 3 oz spinner on the nose is 24" from the wing tube (that's a lot of torque in the cg balance equasion). That would require me to move 8 oz of batts back 9" (from the engine box to the fuel tank, approx) to be equal
    Gatorb8
    (gone fishing for a few days)
    Phucifino 3D
  21. #7696
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gator, what you're seeing is the diff between sim and real world. Real world is always harder from my experience. I have the same exact problem that you are having. The first one is good but the 2nd one gets squirrely. This is exactly how I lost my 87" Yak in the snow a few years back. I'd say to keep practicing (high !!!). I did my 2nd one only 20 feet off the deck when I crashed and lost orientaiton in the haze (I also panicked). Just keep practicing. I had better luck on the sim using aileron and rudder....just like in harriers. I use both.
    When the CG is too far back it balloons on landing. That's the only thing I don't like about CG's too far aft. And with 3 oz CF spinners it can cause you to have to shift the batt's pretty far forward. I'll leave mine next to the tank for now. If anything they will go more forward....not back.
    Joe AP
  22. #7697
    Join Date
    Mar 2002
    Randolph, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I remember QQ saying you can tell when the CG is good when you can land hands off and the planes settles in on the 3 point landing.. I'm with Joe I hate when it balloons on landing.. Giving some dwn. trim for landing should help..
    www.njjf.org
    www.gsrcrc.com
  23. #7698
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Abother thing it seems to do is bounce off the wheels/gear when it's too far back. It just doesn't want to stick to the ground. Then you get people saying "does that count for three landings?".
    Joe AP
  24. #7699
    Join Date
    Oct 2005
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can check if you need to mix a little down trim at idle. Take the plane to altitude and with the engine at idle put in into a verticle dive. It should dive straight straight and not pull to the canopy. Usually takes a little down elevator mixed with idle to get it to dive straight. This will also aid in the landings.
  25. #7700
    Columbo's Avatar
    Join Date
    Aug 2002
    Norman, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pretty much done with mine. Hope to test fly it within the next few days. My setup is simple and includes JR 8611a on all control surfaces. Dl 50 engine, 1900 ma 6V nicad battery for receiver and 1100 nicad for ignition (plan to switch to a123 on receiver next flying season). JR R945S Duel conversion PCM receiver. Used all the included hardware. I started
    the DL the other day and it runs great out of the box. Will run on synthetic 40-1 mixture for 5 gallons then switch to 50-1.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
