Extreme Flight 88" Yak - Build and Fly
#8301
My Feedback: (17)
ID
RE: Extreme Flight 88
ORIGINAL: JoeAirPort
Weather has been rain and wind around here.
Hey flygilmore, I have converted another DLE-55 to a velocity stack. Bone dry after flying 5 flights. Ithink these things stop the spray at the source. Also my fuel economy seems better. OF course neither of those were the reasons I went with the v-stack. It was for consistant mixture at all flying attitudes. That works great too.
Barry
#8302
My Feedback: (41)
ORIGINAL: Barry Cazier
Joe, Where do you get the V stack for the DLE-55? I bought one of those engines to put in my Edge. I'm gonna start the build later this week. Sounds like something I ought to install. Where do you get them? I haven't ever ran a DL but the 55 interested me so I got one to try.
Barry
Barry
The V-stack can be purchased from ValleyviewRC. They only cost a couple of bucks or so...less than $5. Jedijody is tech support for Valleyview and is around here posting...mostly on the DL/DLE threads in the gas engine forums. PM him and he'll set you up. The V-stack worked so well that I put it on both the DL and DLE engines. Get 5mm longer bolts. Use blue lock tite and don't over torque as the V-stacks are just a hard plastic. Mine work great. I was tossing my plane around all afternoon and the engine never knew it. Just kept ticking along.
#8303
My Feedback: (17)
ID
Great, I'll find him and order one.
What is the difference between the DL and DLE? Mine is a 55 and I'm thinking it said DLE on the box, but now I'm not sure.
Barry
Barry
#8304
TX
Barry
Barry
#8305
My Feedback: (41)
Yeah that's pretty much it. The DLE jug might be just a little bigger due to larger cooling fins. At least it looks a little bigger to me.
On my DL-50 I'm getting 7400 RPM onXoar 22x8 using stock exhaust (about 2-3 gallons Pennz 32:1). My ZDZ 50 NG pulled the same prop at 6900 on a Supersonic wrap around. The difference in power is incredible. Once Iget more gas though the 55 I'll get a tach measurement. It's already pulling like a mad bull.
#8309
My Feedback: (10)
TX
ORIGINAL: Gatorb8
Good to meet you too cjcyclesrc!
Hope you didn't get too much rain on the way home, I hit it all day Saturday, took 10 hours.
We need to do a YaK rendezvous at a future Joe Nall. We could line up at all flight stations and have 5 YaK's up at once. That would be a cool video & photo session!
Gatorb8
Gatorb8
That's a great idea for getting all the EF's up at once. A definite must dofor next year.
I was hoping someone got some pictures when Lee and I flew together on Friday. It wascool seeing both the 110's flying in formation.
#8310
My Feedback: (15)
NJ
I got 3 or 4 more "free" flights on buddys' EF 88" Yak. A few things were clearly better than my TOC-E Yak, KE is so easy, if I held any rudder at all, it climbed! I wanted to do a low KE pass but couldnt get it low. I'm used to holding lots of rudder. Waterfalls and inverted flat spins were better and landings, well, you just about have to cut the engine to get it to land, what a floater. The control in hovers was a little less than TOC-E Yak and pull out was a bit sluggish, but enough. It has DA50, Xoar 22X10, 7100R's. Dont know the weight yet.
#8311
My Feedback: (41)
Tell me about it.....I was used to flying this Yak all spring. Then I got my EF Extra going. Itook it out to the field and my knife edges were all diving toward the ground. Ihad to get used giving morerudder. So then Idid my first my take off into a knife edge climb out. And right after I'm high enough, so the wings are clear of the ground, I roll into knife edge.My left wing tipended up less than a foot off the ground for about 10 feet. Man talk about a thrill. Luckily Ididn't stick thewing. And what really sucks is nobody saw it. It looked impressive (it was an accident of course).
Now when I go back to the Yak all my knife edges will climb.
#8312
My Feedback: (29)
AZ
ORIGINAL: Hughes500E
A picture that puts the size of our YAK in perspective.
My Yak sitting with two 75/85ccAeroworks machines.
#8313
FL
ORIGINAL: diamondave
if anyone is making there way through arizona let me know, be cool to see some of you guys
I'm in Colorado for the summer and I'm afraid if I got to AZ I would melt!
In BV CO it's 50-60 in the morning and tops outin the 80's on a HOT HOT day!
Can you fly in the dead of summer? I'm guessing it's like fishing in florida in summer, up at 4am, fish, drink, catch fish, clean fish, sleep by noon!
If any of you guys get to CO in the summer hail me! The back drop of the field in BV is the contentinal divide, multiple snow covered fourteeners, cool weather, low winds in the morning, hold on to you plane in the afternoon!
cjcyclesrc,
Glad you waited out the rain and got home ok! Definately see ya next year! We'll do an all up Yak-off!
Gatorb8
#8314
NJ
#8315
My Feedback: (29)
AZ
gator that would be cool up there...i do fly in the summer but out early, daybreak kinda thing, by 10-11 its pretty hot, we do have a pavilion for some shade, soda machine, i bring a jug of water too, but you do get hot just in the 11 minutes of flying out at the line, maybe thats another reason i keep my timer short and land with half a tank still
#8316
Got my notification that the Yellow/Blk Yak will arrive early next week..... After reading this post I'm pumped about getting this plane and putting it in the air. Once I get it put together I'll post some pics. Looking forward to the WOW........
#8317
I do have one question, I'm using a DA 50 on this plane and I've heard several comments on using 2.5 to 3" or more standoffs. What is actually the best to use? Is the main reason for the cowl to be offset a little less than what the manual says or is it to help with counterballancing to obtain CG?
Thxs
MC
#8318
NJ
ORIGINAL: MSC
I used the stock 2.5" standoffs that came with my DA. The CG works out fine with the KS 1060 Tuned Pipe and the batteries and regs all the way up on the side of the motor box..
#8319
My Feedback: (41)
ORIGINAL: MSC
#8320
My Feedback: (41)
ORIGINAL: MSC
Thxs
MC
Thxs
MC
#8321
NJ
3" is too much. 2.5" is good. Mine are about 2.7" and are perfect. They are DL stand off's. I like my prop to have some space between it and the cowling. It not only helps push theCG forward but gives the prop better efficiency. I don't mind at all the looks, in fact I prefer that look.
ORIGINAL: MSC
Thxs
MC
Thxs
MC
#8322
Thks, sure there will be more questions coming. Nothing like the excitement of a new package arriving at work and everyone Ooooing and Awwwing over a new plane..... If only UPS was quicker......tick tick tick tick amazing how slow time will pass when I'm waiting.... and how fast it goes by when I'm at the field.
#8324
My Feedback: (29)
AZ
well there was a death in the family on memorial day, the red-headed step child took a shot
http://www.youtube.com/watch?v=lGDh7YDOgRA
#8325
TX
On a happy note, Igot a few flights in on my red-headed step child this past weekend &everything went great.
Also flew the 88"er and got the needles tuned much better. The low speed is just a hair under 1 turn now and the high side is a hair under 1 1/2. I tached it (warm) at 7300 ona Vess 22A and the transition is great. Still a bit of burble under 1/4 throttle, but I'm not concerned about that. I've only got about a gallon through it so far. It's still doing the inverted power-loss thing, so I've gota V-stack on the way to try out.
