If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 430 of 440 FirstFirst ... 330380420428429430431432 ... LastLast
Results 10,726 to 10,750 of 10976
  1. #10726
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extreme Flight 88
    ORIGINAL: Slow and Steady
    I use Life and measure use by fully charging at field before 1st flight. Keep track of minutes on each flight and recharge when 4 flights completed. Divide Mah added by total minutes or total flights, provides mah used per average flight.
    That works great for LiPo's, LiFe's, and A123's. Due to the way Nimh's charge that way doesn't work well for them.
    Charles
    Fly Extreme!
  2. #10727
    Join Date
    May 2009
    Fort Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I gave up on NMH about a year ago. Have used Lipos for my receiver since then, until about two months ago when I switched to Life. Don't know whcih I prefer more, the Life or Lipo. Life seem to be more stable. I have also heard recently that the charger I used on my Nmh batteries was not very accurate at topping them off, which may have contributed to their performance.
  3. #10728
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    charles that sounds like a lot of work....im going with a123 on the big one, my edge will stay methdrides for now, i know my current set up can fly me for a day without charging so thats enough info for now on these batteries.....thanks for the helps
  4. #10729
    Join Date
    Apr 2004
    saint andre de cubzac, FRANCE, METROPOLITAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hello,
    i have now nine flights on mine (four today), my CG is too aft for me but the most important problem: i have to add about 31 clicks of uptrim on elevator (5 mm of throw). It was most important before today because i have now nearly one degree of upthrust. Do you have a solution (i have already check incidence and it seems ok, i have to check that another time to be sure) ?
    Stephane
  5. #10730
    Stephane, no upthrust is needed. The Yak should be set up 0-0-0, which is 0 degrees for engine, 0 for wing and 0 for stab. Check to make sure their is no reflex in your ailerons and confirm proper CG using the 45 degree line test.
    EXTREME FLIGHT RC
    State-of-the-art Aerobatic Aircraft and Accessories
  6. #10731
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks chris,
    i though strange to put upthrust, but i have to change my CG and check another time everything to solve my problem (0 degree everywhere). What is reflex chris ?
    Stephane
  7. #10732
    Reflex would mean the ailerons would be raised slightly from neutral. This would cause a lot of problems.
    EXTREME FLIGHT RC
  8. #10733
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok i understand, but i dont think it is my problem. I will check another time incidence to be sure and will tell you...
    Stephane
  9. #10734
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: diamondave
    plus, i forgot to say im kinda thinking ahead a bit, if ef announces a 80cc or 100cc edge at some point i most likely would sell my 88 edge to try and get the bigger one, like i did with my 88yak, then i transport the 2300s into that one, darn ef always making me want new and more expensive planes
    RJ Gritter flew a prototype at the XFC this summer.
    Jeff
    Extreme Flight RC, www.bandegraphix.com, team Airtronics
  10. #10735
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: cjcyclesrc
    ORIGINAL: JWilliams
    Getting the yak dialed in for the King 50. The OS55 is really running good, idles about 1700 and top end at 7400 with a 22 X 8, going to a 23 X 8 tomorrow will post results.
    Jeff Williams
    Cool. One of my friends brought out an OS 55 this weekend at the Austin big bird. It's seems to be a great running engine. I wish I could get loose from work to go to the King 50. I've got my 88'' Edge dialed in and ready.
    Charles, guess we will miss each other at Atlanta this year since Chris moved it to Macs. He might do it next year in October he said, just not an official huckfest. Anyway, yes my OS55 is running great, I am pleasantly surprised as I am a die hard DA guy.
    Jeff Williams
  11. #10736
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JWilliams
    ORIGINAL: JWilliams
    Jeff Williams
    Jeff Williams
    The timing was bad for me to make it this year for me to make it to the All up Huck. It works out great for me at the GMA field because My parents only live about 30 min north in Cleveland, GA. I'm going to be coming home for a week some time this Fall. I'll plan to time it for the unofficial fly-in.
    Charles
    Fly Extreme!
  12. #10737
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JWilliams
    Jeff
    i believe that was an extra, i want a bigger edge....someday im sure they will do one, they are in it for the long haul, and when they do it will most likely become the best model in that size class, just like they always do....maybe someday a pitts m12 biplane to make that "beast" look like a ground squirrel
  13. #10738
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh, I thought you meant an Extra. Whooooooooops.
    I am sure Chris wants to do a larger Edge, I will talk with him about it next week at the King 50.
    Speaking of King 50, getting my borrowed from Chris Hinson 88" Yak dialed in and looking forward to flying it in the King 50 next week.
    Jeff Williams
  14. #10739
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cycles, the unofficial is not till next year (if then). Chris said he has been to so many events this year he is just worn out.
    Jeff
  15. #10740
    Join Date
    Mar 2010
    East Rockaway, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally getting my yak out for the first time in about 5 weeks.
    So excited......
  16. #10741
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool. Enjoy.
    Joe AP
  17. #10742
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Whoa over 10,000 posts. I need help.
    Joe AP
  18. #10743
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOW!
    ORIGINAL: JoeAirPort
    Charles
    Fly Extreme!
  19. #10744
    Join Date
    Jan 2007
    perryville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well my yak is toast...deadstick. coming in to hot with wind at my back. I was at a fly-in to many people to land anywhere but the runway, tried to land in the bean field but overshot it, hit at tree. so, should I get an EF extra or an EF edge? power plant is going to be a BME 58. Do you think the nostrils in the cowl will effect the side carb of the BME?
  20. #10745
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry to hear about that. If I were you I'd get the Edge. It's new. I wouldn't worry about the side carb. You can put a velocity stack on it to clean up incoming air.
    Joe AP
  21. #10746
    Join Date
    Mar 2002
    Randolph, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DANG Joe ! You need a life man !!hahaha!! And they call my friend the "Keyboard Flyer"!!
    Frank..
    PS get the Edge !
    www.njjf.org
    www.njjf.freeforums.org
    www.myspace.com/xtraflyr
    www.extremeflightrc.com
    www.gsrcrc.com
  22. #10747
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xtraflyr
    DANG Joe ! You need a life man !!hahaha!! And they call my friend the ''Keyboard Flyer''!!
    Frank..
    I know Frank. It's crazy. If you click on the number of posts above my avatar it shows you the number in each year. 2004 was my sickest year. Almost 4000 posts. Last year was the 2nd most. This year is the lowest. Maybe I'm starting to wear down.
    Joe AP
  23. #10748
    Join Date
    Mar 2010
    East Rockaway, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe your out flying more.
    Anyway, out for some more yakin off on my 21st b-day. Sunny, 75 and light wind. Should be a great day.
  24. #10749
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rained all weekend. No flying for me. First week in a long time.
    Joe AP
  25. #10750
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And this time I saw the crappy weather coming so I took Friday off work. Yessssssssssss!
    Today I went back to my Xoar 22x8. Big mistake. I'm switching back to my MSC 22x8. It's a waaay better 3D prop.
    Today I saw an EF 78" Extra 300 go in. Sniff sniff. Like losing a family member. The older gent has trouble seeing and flew way too far out. Lost it. Not sure if they ever found it. Sad.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1509458   Click image for larger version.
ID:	1509459   Click image for larger version.
ID:	1509460   Click image for larger version.
    Joe AP
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
