Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 88" Yak - Build and Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 03-27-2007, 02:55 PM
  #1401
Whirlyspud
Default RE: Extreme Flight 88" Yak - Build and Fly
My brother worked for UPS. The stories he used to tell.....I've been pretty lucky with them myself. LOL, Now he works for FEDEX, and they just did a hell of a number on a helicopter I shipped in a plywood crate.
All I can say about my other brand yak is that it is a much smaller looking plane and it weighs at least a pound and a half more than this one will. The landing gear mounting on this one is worlds better also.
I pissed and moaned a bit when I made a stupid mistake drilling my firewall, but I don't hold that against the plane or EF. Just my own dumb ass fault! I've been happy with every EF plane I own. This is the 5th or 6th. They way EF handled a problem I had with an early extra kit earned them a customer for life. Sorry Chris, but I will be back for more. I'll try not to do anything stupid and ***** about it online. I've been looking hard at that new pattern looking electric they have. Only thing keeping me from it right now is I promised the wife I'd crash something else off first. I wonder if she would count a bashed foamie. If so, I'm gonna crash something tonight after work.
Mike
Old 03-27-2007, 03:03 PM
  #1402
yarom
My Feedback: (82)
yarom's Avatar
Actually, these were figures I got on another plane with 6 8411s, one 8611a and two 811s.
I note the charge amount in the shop to track the consumption and it has been very consistent in terms of the amount used for a 12min flight.
ORIGINAL: juanvaldes_04
I believe you´re using 5955´s all around right Josey and yarom?
Old 03-27-2007, 04:44 PM
  #1403
juanvaldes_04
Just got mine, this thing is HUGE in person!!!
For any eurpeans ordering, keep in mind you have to buy a fuel tank. No fuel tank for us []
Old 03-27-2007, 05:39 PM
  #1404
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Did you check in the cowl box?
Old 03-27-2007, 06:43 PM
  #1405
cwhite
My Feedback: (42)
For you guys using the Brillelli w/stock muffler, are you having to us expo on your throttle. I have a JR 6102 and it doesn't have that feature.
Old 03-27-2007, 06:44 PM
  #1406
bgold
Has anyone used the new Hitec Fusion 9 receiver. It's synthesized and sets to your transmitter frequency with the push of a button. Actual 9 channel rx. My LHS is recommending them but I'm not sure. Price is only $99.00.
Old 03-27-2007, 06:48 PM
  #1407
joel mccollum
joel mccollum's Avatar
Has anyone flown this plane yet on the stock exhaust yet like tho here how it done before I order exhaust system.Haven't got started on mine yet I'm finishing up a Q102 yak before I can get building this one. EF yak looks to be alot better Quility then Q yak can wait to get started.
Old 03-27-2007, 06:51 PM
  #1408
Bosshossv8
My Feedback: (10)
If you don't have expo on throttle, just make sure to get full travel AKA 100% by physical geometry of the arms and linkage.. That way at least you will have full resolution in the control ...and smoooooth linearity in repsonse.
If you have to cut down the throws in the menu's...the resolution goes to heck.
Old 03-27-2007, 06:54 PM
  #1409
CHM
My Feedback: (28)
CHM's Avatar
Wouldn't HS-5985's be plenty on the ailerons and elevators?
Old 03-27-2007, 06:56 PM
  #1410
EXTREME FLIGHT
EXTREME FLIGHT's Avatar
I was wonderig when you were going to join us Bosshoss. Havent seen you here in a while.
Old 03-27-2007, 07:05 PM
  #1411
Josey Wales
My Feedback: (61)
ORIGINAL: cwhite
No expo but I am working on a throttle curve..right now I have my hovering/t-roll setting but need to get the rest of the curve down..Im using a 6965 with ATV's at 125 each way..You can get close with expo though...
Old 03-27-2007, 07:08 PM
  #1412
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: CHM
I'm running all 5945's, even on the rudder, watched Chris do a knife edge loop with it last weekend and it's fine. I see no need to run 5995's, unless of course you have them.
Old 03-27-2007, 07:25 PM
  #1413
MustangAce
MustangAce's Avatar
Two questions. I have the DA50 with stock muffler and 3" standoffs. Can I get an inch of prop clearance from the cowl and not have CG issues?? Also, can the PSP titanium axles be used with the spats with no mods. If not, what do I need to do?? Thanks in advance.
Old 03-27-2007, 07:30 PM
  #1414
bgold
I just orderd 2-1/2" standoffs for my DA-50, the three inch pushed the engine to far forward and besides balance it looked to me like the engine was starting to come out of the cowl, forward.
Old 03-27-2007, 07:37 PM
  #1415
jrjohn
My Feedback: (24)
ORIGINAL: MustangAce
I doubt you could ever get too much weight on the nose of this plane. Usually its the other way around. As a matter of fact if you can get the batteries off the engine box, it's much better for the batteries not to be close to all that vibration. I really think 3'' is the way to go if you can get good standoffs with a big base on them. Mine will be done soon. You don't use 3'' standoffs and keep the cowl overlap at 3/4 of an inch, instead you set the overlap at 3/8 or so. Hopefully I"ll have pictures by Friday. I would not use DA 3'' standoffs, the base is just too small
John
Old 03-27-2007, 07:53 PM
  #1416
Mike Parsons
Mike Parsons's Avatar
Now for something completely different
86 mb
http://higherplaneproductions.com/media/EF_88_Yak.mov
Old 03-27-2007, 07:56 PM
  #1417
krayzc-RCU
My Feedback: (31)
Maudib
what is the total lenght of that DA header?
tks
Old 03-27-2007, 07:58 PM
  #1418
flyingcrazy
My Feedback: (28)
Here are my 3 in. standoffs, I made my washers out of aluminum and a hole saw then I polished them , I also have them behind the fire wall .
Old 03-27-2007, 08:03 PM
  #1419
Josey Wales
My Feedback: (61)
ORIGINAL: Mike Parsons
86 mb
OMG!! That is a classic!![sm=lol.gif]
Old 03-27-2007, 08:08 PM
  #1420
jrjohn
My Feedback: (24)
ORIGINAL: flyingcrazy
Thats what I'm talking about, Sweet!
Old 03-27-2007, 08:09 PM
  #1421
Jake Ruddy
My Feedback: (40)
Jake Ruddy's Avatar
86 mb
Would be watchable if it wasn't quicktime.. that crap highjacks a PC continuously no matter how you set file types.
Old 03-27-2007, 08:23 PM
  #1422
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: sinergy
86 mb
Installed correctly it works fine..
Old 03-27-2007, 08:24 PM
  #1423
Maudib
My Feedback: (51)
Maudib's Avatar
Not really... there is a "QT only install" and you can set it to only play QT...
but I'll have PC friendly WMV's shortly...
Old 03-27-2007, 08:31 PM
  #1424
Maudib
My Feedback: (51)
Maudib's Avatar
OMG... I CAN'T STOP LAUGHING!!!!!!
A NEW video from Weird Fred "Yak"-o-vich!!! HA...
I like big props and I cannot lie, all the eother yakker's can't deny...
When I throttle to the top, the engine never stops and my 88" goes sky high!
Yean baby!
O.K.... converting for you WMV Lovers... hang tight!
Old 03-27-2007, 08:45 PM
  #1425
MustangAce
MustangAce's Avatar
Thanks guys.
