Control throws for 33% Edge?
Banned
These guys are going to want to know what plane you're referring to and about 20 other questions. While you sort that out with them I'll give you some approximates:
Low Rates:
Ailerons = 1.5" up and down
Elevators = 1" up and down
Rudder = 4" right and left
High Rates:
Bevel to Bevel, Baby!
Mid Rates:
In the middle, naturally.
From there I'd just fly it and adjust according to how I like to fly.
You know what? I'm assembling an AW 33% Edge ARF right now... I should check the manual. I will next time I'm out in the garage and report what it says. :-)
Low Rates:
High Rates:
Mid Rates:
TX
If it is the 33% Aeroworks Edge, the throws are not much at all! I can measure them tonight when I get home. The elevator in particular, has a very, very small amount of movement.
My Feedback: (7)
Control throws
Actually, this is a godfrey/hostetler, however, I doubt the throws are much different than the AW. My question is really whether I should increase the throws from a standard setup to allow hovering capability or are the stock throws (like those above) enough? No, I don't necessarily like to hover, however, if I ever wanted to try and the aircraft was not setup for it, I would'nt want to sand the LE of the control surfaces and recover.
Banned
Re: Control throws
How much throw for hovering maneuvers? All you can get our of your current beveling... and a 3D pilot would probably want even more. 45-50 degrees on the elevators for instance. Don't forget to dial in plenty of expo.
Check out first video here:
http://home.earthlink.net/~jb01/the-gang.htm
If I didn't have 50 degrees of throw in the elevator I could never keep that CAP hovering. Of course, major rudder and aileron are desirable, too. :-)
