Sirius Quad Charger & Common Ground?
My Feedback: (198)
RE: Sirius Quad Charger & Common Ground?
ORIGINAL: niteman
Hi Joe,
Thanks for the reply. I've Read Red's advice many times, good stuff. However, "redundancy" is in case of 1 rx pack failing (catastrophic failure), right ??
I think others, like me, have great success in delivering max usable power (amperage) to the rx with two direct connects etc..., but George at Peak Electronis who I would think has to know a thing or two about this topic seemed pretty sincere that as far as "redundancy" goes, it is very questionable at best if one of the rx packs fails could drag the whole sytem voltage down with it. You know, I recall a real informative technician at MPI I spoke with some time ago warned me that "redundancy" in this type of setup will not work no matter what type of short. Like I said, I am electronically challenged so I am not making any claim to be an expert, thats why I like Peak Electronis Products, there easy to use.
My main point of the post was to see if the quad charger can charge with a common ground between 2 packs and it can't properly according to George.
Appreciate all the advice.
Hi Joe,
Have to admit - there is no way in the world I would get a bunch of added on complexity (read "additional failure modes/points") to something so easy to make work perfectly.
Sirius chargers are just ideal for this..... a few minutes between flights on each pack..... I can't fly enough in one day to wear down my dual Hangtimes 1900 low-impedance NiMh's on my 30%'ers.
IL
Hey Bob,
Thanks for chiming in. Got alot of good advice from your site in the past, thanks. I agree with your take on keeping it short and simple.
The only advantage was added protection of having one battery short (rare I admit) and not take down the other, provided the back'r doesn't fail in the loop as you suggested.
I also did not realize or have tried, (because I'm still waiting for the my quad charger to come ) that charging one at a time would solve the ground loop, at least for one at a time.
So the other battery not being charged, but still sharing the common ground, does not inhibit the the ability of the quad charger to detect the real mah's left in the battery your charging ?? No false peaks etc..??
Really appreciate your reply, Dan [8D]
My Feedback: (61)
NJ
Yep..if you only charge 1 pack at a time there is no common ground issue...
Bob..don't bring any common sense in this..we frown upon that!
My Feedback: (198)
No issues at all. The non-charging battery is not in the circuit. THe MPI switches open the + side of the battery. So the charger is only sensing the one connected. It doesn't "see" the other battery at all. You can check all this with an ohmmeter; measure in the charging jack of your switches red to red. With both switches "off", in the "Charging" position, there is no connection.
With them "on", then yes, both + battery connections are tied together effectively through the + side of the receiver. They share both the + power buss and the negative terminal in the RX circuit.
Actually, you can safely charge BOTH using MPI switches.
Now - if there are switches out there that switch the NEGATIVE wire of the batteries, then George is absolutely correct, as the Sirius would be "seeing" both + terminals through the shared ground on the Rx.
I seem to remember there are switches out there that switch the negative lead (make/break the black wire from the switching action). That would be a problem, for sure.
IL
[quote]ORIGINAL: aerobob
Does that mean you have charged both batteries at the same time through the MPI switches-charge ports with no trouble ??
#31
My Feedback: (198)
Yes. But it is working because the MPI switches break the positive (+) red lead internally, with the black tied across. The DPDT terminals have the red connected to both, to produce mechanical internal redundancy in the switch.
#33
IL
Happy 4th !!
Hi Bob,
Can you confirm for Joe and I which MPI switch you use ?? Is it the MPI Standard Heavy Duty Charge switch like the: SOFT MOUNT ONE-PIECE CHARGE SWITCH (http://www.maxxprod.com/mpi/mpi-4.html)
OR are you using the MPI 6 volt regulated miracle switch: http://www.maxxprod.com/mpi/mpi-21.h...racle%20Switch ??
Thanks a million Bob
Hi Bob,
#34
My Feedback: (18)
ORIGINAL: aerobob
I've been looking for HD charge/swtiches that break both + and - so that I can stop pulling a plug, but so far have not found any... The common ground issue is one reason I am looking at the Dual-Battery Regulators from Smart-Fly...
#35
My Feedback: (61)
NJ
Wouldn't it be easier to design a charger to handle the common ground ? The only chargers Ive used that can handle this is the Alpha 4 and the Fromeco Reliacharger....The Spectra can handle it but I never used or seen one in person...
