HANGER 9 EDGE 540 C of G
My Feedback: (41)
RE: HANGER 9 EDGE 540 C of G
6 to 6 3/4" from the leading edge at the tip, but since it's a straight leading edge...
Now that's assuming it's the 33%?
Why don't you just download the manual?
http://www.horizonhobby.com/ProdInfo...150-manual.pdf
If it's not the 33%, the manuals for all the others are also available on Horizon's website.
1 Post
ORIGINAL: Zeeb
thanks for the info, sorry i should have said ive got the 78" 1/4 scale one![sm=sad_smile.gif]
ive checked the link you listed but thats for the 33% one only,
thanks for your help, i may be able to work it out from the 33% figures.
Di n Dave...
My Feedback: (41)
Dave,
Sorry about that link as I just provided it to show you that it was available for the 33%. Since I saw several Edges listed, I thought if it wasn't the 33% you could just find yours.
But in checking Horizons website, it appears the model you have is no longer available so there won't be a manual...[]
There is a formula for figuring where the CG is/or should be, but basically it's usually at the center of lift. I don't have a link to a post with that, but try a few searches for that information and see if you can't find it.
edit info:
Aha!
It's not one of the threads I was thinking about, but I did find what appears to be a nifty CG locator on a link posted in another forum here. I've not tried it, but it looks like the real deal...
http://www.palosrc.com/instructors/cg.htm
edit info:
Aha!
NE
According to the manual the 78" H9 Edge has the following balance point, 4-1/2 - 5-1/4" from the leading edge of the wing at the fuse.
Here's the throws if you need them,
Low Rates 3D Rates
Aileron 3/8th up 9/16 down 1-5/16th up 1-1/16th down
Elevator 9/16th up 9/16th down 3" up 3" down
Rudder 3-1/4" right 3-1/4" left 4-1/4" right 4-1/4" left
Mine has a Moki 2.10 Ballistic!!
I would warn you to stay forward for the first flights, it's a great airplane, and don't fold the wings on the downline. These were prone to wing failure.
Low Rates 3D Rates
1 Post
Hi gunfighter11,
A big thank you for all that information! that will ba a great help![sm=wink_smile.gif]
im glad you have mentioned about the wings folding, [X(] i must admit to going a bit mad sometimes, so i will have to be careful!!
Thank you,
Di n Dave....
Pitts
I have a pdf file of the Top Gun Edge 540 its the same plane, PM me your e-mail and I will send you a copy.
Guns you forgott that Terry got me that didn't you.
Mike
Mike
Guns
Your memory is obviously failing you, I wrote it off when my radio decided to stop transmitting, bad aerial connection due to corrosion inside the Tx case.
Mike
EDIT: Don't ask me why it came out that size, I have no idea.[sm=confused.gif]
Mike
NE
Mike,
Your right my memory is gone, it's an age thing.
I remember it now that you showed me a picture.
That's a shame, it's a really nice flying plane once you get used to it.
