Solution X C.G.
My Feedback: (204)
Solution X C.G.
Where is the CG on a solution X the side view shows two points on the I strut, and these two points appear to be at the rear of the cabane. But if you look at the top view of the top wing and draw a straight line from one strut to the other the line goes behind the cabane. Any solutions? no pun intended
IN
Solution X C.G.
Solution x cg
I don't know whose plans you have, Mine are from Miles Reed, Plans show 2 balance points ,These measurements are in front of the rear cabane wire,One is 2 in. and the other is 3 1/2, Hope this helps,
