Performance Aircraft Unlimited 30% Extra 330l SALE!!!
#176
My Feedback: (82)
RE: Performance Aircraft Unlimited 30% Extra 330l SALE!!!
We were actually talking about a weekly or bi-weekly 3D school at our field, during the week.
We currently have our novice flight school every Tuesday from 5pm during the season, which is fairly successful. We are looking at doing something similar for 3D and IMAC flyers. It's in discussion and we will need good pilots that are also reasonable teachers.
I'll see about August 18th availability. I'm pretty sure my wife will not let me oull that many days...
ORIGINAL: Hooked-On-RC
Well John you see you just expressed your ignorance in this whole situation, had you done your research you would have learned I am making nothing off the promotion of a 3D flight school. Secondly I mentioned it in this Forum becuase Yarom had expressed an interest in doing something similar and I thought it smart not to duplicate the efforts when we are located so close to one another. And lastly I am promoting this event for the simple fact there is a growing desire from a large group of flyers to increase their knowledge and skills in 3D flying and why not make it well known there is something available to them in this area.
#177
My Feedback: (82)
Steve, you should lay off the profiles and get going with this bird. I have been done for a week and waiting for final battery packs. Nice 3.5" CF spinner fit just right...
Plane will be on CG with the Lipo packs in the motor box. Have not taken AUW yet as I am consumed by my 35% project and the weather is sub-zero...
ORIGINAL: lenz rc
Here you go The spinner is a 3 1/4" that came with my SD yak 54. I will probably change it to CF to save weight.
#178
My Feedback: (228)
WA
Jerome I here you. I assemble them in the order I buy them. The Extra is my winter project and I am in no hurry. I do have a the servos and radio gear for it in due time I will install them. I had some cool vinyl made for it (three layer colors ) with my own font. I am still not decided if i am going to use Spektrum or Futaba PCM. And after Sun flying and somebody removed my frequency card and putting it 39 instead of 40 . With a brand new plane to boot, I got real lucky it is still in one piece.
#179
Thanks lenz, that's a nice set up with so little of the engine showing. More of mine will show since I intend to use the stock muffler on my DL-50.
#180
My Feedback: (82)
It's a very good time to get rid of the remaining PCM junk and move to DSM...
ORIGINAL: lenz rc
#181
My Feedback: (228)
WA
Jerome did you set a plane up with Spektrum? Will I need to get a Smart Fly Power expander Sport or Pro. Or can I get buy with Just plugging two power inputs from the Smart Fly regulator to the AR 7000 DSM 2 RX I have. [sm=spinnyeyes.gif]
#183
I've been getting caught up on reading the threads after returning from a little time out at sea (no internet) and am also the proud receiver of an Extra as a Christmas present. I had enough time to take the cursory look in the box to see that this was the best packaged ARF I've received, plus the added extras of the CF parts, ballcap, and wing, fuse, and tail feather covers made the cost even more worth the purchase. Hats off to PAU! Now for the really good news:
I've been working with Brad at BadBrad Graphics for the past week on a vinyl package for this bird and wanted to share it with those who still have fresh covvering. This will be the 3rd plane I've put his graphics on and know I won't be dissappointed.
I'll post pix of the plane once I get them on the surfaces (still in the mail) but here is the final drawing that got produced.
To Herve and Ken: Thanks for the great product and support !
#185
AWC,
Those graphics are gonna look great! So glad you are happy with the kit! PAU is becoming known for their hardware "extras"! You should see the hardware kit that comes with their new Edges!!
Keep us posted on your progress and I definately want to see some pics when it is finished!
Regards,
Astrohog
Regards,
Astrohog
#186
My Feedback: (82)
Thanks. You saved me the work. I was going to do this this week with Brad.
I'll ask him for a similar package minus the JR advertising, plus the PAU logo. If JR wants me to carry their sticker, they will need to sponsor me quite a bit...
#187
My Feedback: (82)
No need for a Power Expander.
I have two 2600 mah Lipos going through a SuperReg into the AR7000 (with remote antenna).
Use the safety switch on the SuperReg and you are done.
Ignition is separate using a third Lipo, SmartFly optical cutoff and a SmartFly ignition regulator.
I also use a SmartFly equalizer for the elevator servos. Since the servos are these Tower Hitec clones, they are not programmable.
The only thing I would change later on, is upgrade the Rx to the AR9000 when my new AR9100s arrive for Horizon...
ORIGINAL: lenz rc
#188
My Feedback: (41)
Why not just use your subtrim and end points for each elevator half to synch them? No fancy device is needed. I do this on my 9C and you'd swear they locked together mechanically (speed and position are synched). I do match the linkage geometry before that though. I guess I forgot to mention that.
I stopped using the programmer on my 30%'rs when I realized the 9C setup worked perfectly after the linkage matching procedure (see DOD.com video).
#189
Yarom: I'm going with the Batshare for the twin power setup into an AR7000 rx; no need for a Power Expander like you said.
Each ELE and AIL servo will be HiTec 5645's and each in its own dedicated channel, rudder will be the HiTec 5955 , throttle will be a HiTec 425BB, and smoke will fill out the rest. Smartfly cutoff for the ignition system with a total of 3 batteries at 2700 Ma each.
Going to try a DL-50 this time around. I have a DA-50R in the Yak and want to see the side by side comparisson. At $375, it was hard to pass it up with ignition, standoffs, muffler, and a can of Lawnboy tossed in. What is everyone propping their -50's with? I have a bunch of 22X8's from BME (love the laminated and painted tip look)
Stock gear or swap it with CF? As you can tell, I'm not trying to build super light, but more economical with lots of 'show' to it.
Any other suggestions or tricks before I start the project? I've made a few notes from the older build thread.
All: Thanks for the comments on the grapics, can't wait to see them in person and I WILL be sending before and after pix.
#190
My Feedback: (34)
Finally got around to working up an instrument panel for my Extra. Found some photos on the net and sized them for my purposes. They will fit the bill for IMAC regs.
Just waiting on some 1.5" aluminum arms for the elevator and aileron servos and then it will pretty much be done.
#191
CShep,
Nice work on your instrument panels. Where can I find those and build up my own? I was going to go with the Virtual Cockpit kit but this looks about the same without the $55 cost. They look real sharp, but I think I'll keep the cost down this time around.
My Feedback: (34)
AWCFlyer, thanks! I found the images on Airliners.net Opened them up in photoshop, did a little cutting and resizing to the needed dimensions and then printed on photo paper. 3M77 on the back and stuck them on. If you have photoshop, I can send you the images. They aren't in the same league as the Virtual Cockpit kits, but then again it didn't cost me $55 either.
#193
cshepherd, what size pilot is that in your plane? How much does he weigh? I always put pilots in my planes, but not if it will cost me half a pound of added weight. THanks. Jon
#194
My Feedback: (228)
WA
Cshepherd that looks great for Free. - photo paper and $$ software program Do you want to copy me a set I will set you up with something? Or pay you for them. I was wandering if you had a DL 50 I had some extra decals to trade . I looked back in the post and found a pic of your motor are you using a BME for power? Rats
#195
My Feedback: (34)
Jon, It is the 1/3 pilot from Great Planes. My part # was gpmq9006. No idea on the weight, but def not 8 oz
Lenz, I can print you off a set or send you the image files. They don't fit perfect mind you, but they are close enough. PM me your particulars and we can do a little horse trading.
BTW, it is a ZDZ 50RV
Anyone know how I can get the left slider switch on the side of the 9303 to operate my throttle kill or should I just use the gear switch to do it?
#197
Lenz,
Were you wanting a copy of the DL logo? Got it from BadBrad Graphics. He can also make them in any size you want/need.
#198
My Feedback: (228)
WA
ORIGINAL: AWCFlyr
Lenz,
Lenz,
Cshepherd Zdz 50 will have some crazy power. I sent you a pm for some instrument panel copy thanks for your reply guys.
#199
Dash instruments completed thanks to CShepard. I added a little personal touch to mine with pix of the family. Now I need to get a good looking pilot somewhere.
