Extreme Flight 110" 100cc Yak 54 Build!
#376
My Feedback: (61)
NJ
RE: Extreme Flight 110" 100cc Yak 54 Build!
At this point it looks like by the time they get shipped out its more likely that we wont see them until June-
Looks like I may have to look at plan B
#378
My Feedback: (61)
NJ
ORIGINAL: rcairmike
you know you will only kick yourself for going to plan b and not waiting for the ef
#379
My Feedback: (17)
QC, CANADA
It's amazing to see so much loyalty to one supplier when there are so much others good products available and in stock. Personnelly , I would not loose a season waiting for a plane but it's me and i admire those who do that. [sm=thumbup.gif]
Daniel
Daniel
#380
SC
[/quote]
No Plan B is to drive to EF's headquarters and camp out on the front lawn until I get my Yak!
[/quote]
Do that and Melissa will send the beagles out to pee on your tires.
#381
My Feedback: (40)
ORIGINAL: Scoubidou
Daniel
Daniel
#382
My Feedback: (61)
NJ
ORIGINAL: Scoubidou
Daniel
Daniel
ORIGINAL: Absolut Yak
#383
My Feedback: (74)
TN
I just hope that when they call I can get off from work and head that way. I am going to have to take the trailer to get them becasue I will be picking up two of them. If they get here on time I hope to have mine in the air by the end of May.
#384
My Feedback: (24)
VA
Are all of the first shipment already spoken for? I was curious if he might bring some to sell at "3D Unleashed" in High Point NC on June 28th.
#385
FL
ORIGINAL: Josey Wales
I can understand that-It does suck that there have been so many delays..I have had about 6 EF planes and have flown some other brands but they just don't stack up IMO...so I will wait
Ill wear my waders!!!
ORIGINAL: Scoubidou
Daniel
Daniel
#387
My Feedback: (19)
IL
maybe someone could help clarify this for me.in my comp arf yak im using a swb cable tray to gang servos for rudder.i was told that when using the method outlined for the ef 110 yak on the slave servo for rudder, you dont need to connect both link arms.one arm is just fine.
#388
I think that one servo connects to the next servo and that servo connects to the arm that pull-pulls the rudder. The system will work if one servo fails or only one is hooked up but you won't get the effect of both servos that way, it's just a setup that allows it to work if only one servo is operational.
#389
My Feedback: (19)
IL
i fully understand how the set up works.let me explain my question better.on the slave servo on the ganged rudder servos.is it needed to run 2 links off the servo arm of the slave servo to the main servo with the 4 inch of set witch the pull/pull cables are attached to.you would think that 2 links of the servo arm to the othe servo arm isnt needed.just one link
#391
My Feedback: (74)
TN
No wheel pants. It has spats. I am pretty sure that you can 4.5" tire with no mods. If you use a 5" tire I think that you will have to trim the spats just a little.
#395
My Feedback: (22)
Yes, pics and video please. I was planning on visiting the Joe Nall for the first time this year but someones wedding is this weekend. I hope to get a new plane in the next 1-2 weeks for my gift!!
#396
My Feedback: (74)
TN
pfoot7487 congradulations on the wedding. I was going to go to Nall but work has me a little vogged down right now and the timing was just bad.
I am with you on the 1-2 weeks. I think that we may be building us a few Yaks around Memorial Day. I actually get that day off so that gives me an extra building day.
#397
My Feedback: (22)
I look forward to seeing your build along with others. I know you will be flying yours long before me as I still have no engine for it. I'm sure when it's sitting on my workbench that will motivate me to gets all the parts to get it in the air. I hope we get to see Chris's original scheme w/ 85 & Greeve's pipe flying in the next couple days. I still think I'm going new DA-100 on stock mufflers though?
#399
You guys, who already have got your plane, did you got the manual with it? I didn't. I have asked it couple of times already from EF and FS-RC, but still haven't got it. For some strange reason the manual is not in the EF internet pages. Do you know if the manual is available from some internet page?
R, Valle
R, Valle
#400
Well have made some progress over the last few days, not as much as I would have liked but the weather has been great here in the UK so I have been flying my 50cc YAK!! Have the servos in the wings & stabs, engine in with the cannisters and just mounted the rudder and cowl. Here are a few pics.
