Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Extreme Flight 110" 100cc Yak 54 Build!
Reply
Old 12-13-2009, 04:28 PM
  #1651
JWilliams
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Extreme Flight 110
Mowery1, you are close to me I am in New Albany, IN area. Bedford is not too far from me, have not heard of anyone close electrifying one of these. Should be interesting.
Jeff Williams
JWilliams is offline
Old 12-15-2009, 08:47 AM
  #1652
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im currently building my yak 110 i recently purchased. im impressed with the quality and the packaging done to insure a safe trip. as im building its amazing to me that they didnt forget any of the nuts and bolts. my last build with aeroworks always resulting in calling for missing parts. my only wish is that it came with wheels and axels with the kit. it was a real pain to go out and look for these parts. alot of local hobby shops dont deal with large rc parts... Can any one send a picture of the bottom cowl with a da-100 with stock mufflers installed? not sure where to cut. thanks for any help
keith124 is offline
Old 12-15-2009, 09:13 AM
  #1653
taildragger21
taildragger21's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: keith124
The cowl is so huge the only place to cut is for the exaust tubes..
taildragger21 is offline
Old 12-15-2009, 11:05 AM
  #1654
diamondave
diamondave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i also cut out the inside of the "oil pan" area to help with more air flow, i'll look to see if i have any pics of the bottom.....i made slots for the exhaust so i can slide it on easier
diamondave is offline
Old 12-15-2009, 01:08 PM
  #1655
EXTREME FLIGHT
EXTREME FLIGHT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nogyro, I have had no problem getting 45 degree throws both directions with the 1.5 inch arms. I used the Hitec programmer to get maximum travel and set the end point adjustments in my 12X close to 150. However, if you are having issues, you may want to try the SWB 2" arm. There is a hole at the 1.75" mark and this should make it easier for you. Hope this helps.
Chris Hinson
Extreme Flight RC
EXTREME FLIGHT is offline
Old 12-15-2009, 01:23 PM
  #1656
Nogyro
Nogyro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chris,
I ended up coming into the lower holes on the elevator control horns. That, along with *****g out the servo throw with the programmer could give me well over 50 degrees if I wanted it. I'm using a Futaba 8UAFS transmitter, so maybe that has something to do with the lesser throw.
I did do one other thing. Maybe I'm paranoid, but I envisioned if the bolt ever came loose that holds the ball link in the composite control horn, the thin edges of the ball link would eat into the G10 material real quick. There is enough room in there that I put a 4-40 flat washer on each side of the ball link between it and the control horn sides. Also put a flat washer under the head and nut of the 3 mm bolt that goes through the ball link/control horn.
Nogyro is offline
Old 12-15-2009, 04:58 PM
  #1657
EXTREME FLIGHT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank, in over 6 years of using this control horn/ball link arrangement in our aircraft I've never heard of a single failure, but if it makes you feel more comfortable, by all means use this method. We all develop our own preferences and use what works best for each of us.
Old 12-15-2009, 06:05 PM
  #1658
Nogyro
Nogyro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: EXTREME FLIGHT
That's good to hear, because I really like the design of the control horns. It's sort of like adding the washer to the top of the bolt when you bolt your ball link to the servo arm. It's there just incase the brass ball pops out of the black plastic material. Never seen that happen either, but I still do it.
They did a VERY good job on the servo pockets and horn placement on the wings and ailerons at the factory. I installed the servo's in both wings today and got them programmed. I was able to get the numbers dead on with no binding anywhere in the travel. Both high rates and low are equal both directions. That doesn't happen without good accurate construction and more important, design work to get the geometry correct. [sm=thumbs_up.gif]
Nogyro is offline
Old 12-22-2009, 11:23 AM
  #1659
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally finished putting my yak together it took two weeks but its done. here is my set up. please feel free to comment.
Engine- Da-100
servos- ailerons- 4 jr 8411 ( 155 oz of torque)
rudder- 1 hitec 7950 (400 oz of torque)
throttle- futaba digital high speed servo ( usually used for helicopters on a gyro .55 oz of torque) works well..
2 futaba pcm recievers (one for each Side)
2 4000 nihm Batteries (6v)
1 2700 nihm for ignition (4.8v)
Batteries were installed on the side wall behind the rudder servo. Balance came out to the center of wing tube.
keith124 is offline
Old 12-22-2009, 11:33 AM
  #1660
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: diamondave
i also cut out the inside of the ''oil pan'' area to help with more air flow, i'll look to see if i have any pics of the bottom.....i made slots for the exhaust so i can slide it on easier
I did the same with mine . thanks for the idea
keith124 is offline
Old 12-22-2009, 11:36 AM
  #1661
Barry Cazier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sounds like a very nice set up.
It should fly fine with the CG on the wing tube. I moved mine back slightly from there and couldn't really tell much difference anywhere.
It'll fly good.
When is your maiden flights?
thanks
Barry
Barry Cazier is offline
Old 12-22-2009, 11:42 AM
  #1662
diamondave
diamondave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: keith124
Engine- Da-100
you should have tons of battery for the recievers, im running 2 2000mah mthyd and get suffecient flight time
Old 12-22-2009, 11:47 AM
  #1663
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
maiden flight will be this coming weekend. ill post pictures of setup soon. the 4000 nihm batteries are just slightly longer than the 2700 not very much weight diffrence. i should be able to fly all day with two of those bad boys. wanna thank everyone on this forum i have learned alot from you guys.
keith124 is offline
  #1664
taildragger21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a great setup.. Stock mufflers or pipes?? Here is my latest project almost complete..Eg/omp raven zdz 80rv!! About 22 lbs rtf.. Still can't fly as good as my ef110 though
ID:	1339729   Click image for larger version
Old 12-22-2009, 03:15 PM
  #1665
diamondave
diamondave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats what im looking at for my next plane, exactly, maybe pm me with thoughts on that one, thanks
Old 12-22-2009, 10:48 PM
  #1666
cjcyclesrc
cjcyclesrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: taildragger21
I know the feeling. That's the worst part about the 110" Yak. It flys so good you get spoiled.
cjcyclesrc is offline
Old 12-29-2009, 09:58 AM
  #1667
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Maiden went well. i must say all the hype on this plane is true.. this plane is a keeper. It flew very straight and felt very light.
my cg is spot on. did a 45 upline inverted and after a long line it barely nosed over. i just wish i can get the harriers locked in. I'm having a bit of a hard time keeping the wings from rocking. its not very violent but cant seem to steady it using ailerons. nose is up at a 45. hmmm any suggestions? more tail weight, less elevator throw?
keith124 is offline
Old 01-05-2010, 07:53 AM
  #1668
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found My problem.. It was uneven elevator throw. i did the stick method and got them both tracking very good. harriers are good now.
keith124 is offline
Old 01-05-2010, 09:22 AM
  #1669
diamondave
diamondave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool
Old 01-26-2010, 10:51 PM
  #1670
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can some one help with my elevator set up. i have the hitec 7955tg with the hp-20 programmer. im running two recievers, each elevator on ch2 on each receiver. i was able to match center and both end point adjustments perfectly. i used a 12 inch carbon rod taped on the surface. when moving the elevator slowly or a mild speed they match all the way up and down, but when i move the sticks quickly the right elevator lags behind about .25 sec. i cant figure this one out. control rods are the exact same length. is it a bad servo?
Report Post Edit/Delete Message
keith124 is offline
Old 01-26-2010, 10:53 PM
  #1671
keith124
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im using a futaba 9c PCM reciever running 6volts nihm batteries. i have y harnessed them into one reciever and still same servo. i have switched recievers around still same servo. and have did reprogramming also.. I flew the plane and noticed no bad flight characteristics at all. I even did a wall and it popped straight up no snap. is it worth looking into this more or trying to exchange the servo?
thanks guys for replying. i might be just being too picky about the whole thing.
keith124 is offline
Old 01-27-2010, 10:10 AM
  #1672
Barry Cazier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IT's my belief that this is a normal occurance and is caused by the radio delay in its sorting through all the channels and making the inputs. On other radios: say the 12Z or 14MZ the channels are place closer together which allows for less searching and quicker response. When I moved from the 9CAP to the 14MZ I noticed a considerable difference in this lag time.
I don't think there is anything you can do about it....except just fly it. In most cases as you've proven, it is very difficult to see any problems.
thanks
bArry
Old 01-29-2010, 01:24 PM
  #1673
T Erickson
T Erickson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That lag is called latency, hard for me to get how signals that move at the speed of light can be so slow... my 9c does it too. It is all but eliminated in the 2.4 transmitters, from what I'm told, at least I don't see it in my 9303. Another good reason to go 2.4. Thor.
T Erickson is offline
Old 01-29-2010, 02:42 PM
  #1674
JoeAirPort
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
keith I thought I read that you tried a Y into the same channel and the lag was in the servo?
JoeAirPort is offline
Old 01-29-2010, 03:01 PM
  #1675
cjcyclesrc
cjcyclesrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JoeAirPort
Yes that is puzzling. I would want to figure out what is causing that.
Keith,
Do you have another servo to try?
Reply
Display Modes
