Extreme Flight 110" 100cc Yak 54 Build!
#1726
NJ
RE: Extreme Flight 110
ORIGINAL: Kenrico
Hey Guys,
any one know when EF is going to have planes back in stock?
Hey Guys,
Frank
#1727
gboulton,
you said :'Took a pretty fair amount of up elevator', do you know why ? i have the same problem on my 88 EF yak and this week-end, i will search why.
Stephane
Stephane
#1730
well, i haven't seen that problem last week-end, not the time...i'm wondering if it is possible to be other things ???
Stéphane
Stéphane
#1732
your linkages are still the way they are supposed to be? no servo strip or anything?
yes, no problems here diamond. I have read on rcu most of pilots has this problem, i 'm wondering why...
Stephane.
Stephane.
#1734
My Feedback: (17)
ID
My 110 and 88 both have about 4-5 clicks up trim also. Doesn't seem to effect the way they fly, or if it does I don't know how.
Good flying planes.....regardless.
thanks
Barry
thanks
Barry
#1735
IN
ORIGINAL: Barry Cazier
thanks
Barry
thanks
Barry
Jeff Williams
#1736
Charles,
i have to add about 31 clicks of uptrim on elevator (5 mm of throw), so it's a problem...
Stephane
Stephane
#1737
My Feedback: (10)
TX
ORIGINAL: mm
Charles,
Stephane
Charles,
Stephane
What radio are you using? What do you have the trim steps set to?
Do you have a picture of the elevators with the radio powered on? 5mm wouldn't be much more than the thickness of the trailing edge of the elevator.
#1739
AK
ORIGINAL: diamondave
joe when i used locktite on the collars i had an even harder time getting them off, i used blue, removabel my *****, ended up dremeling them to cut them off, so now i put a dab of clear silicon over the screw when done, i just tried that fuel tube thing too and i like that, i used to put a dap of silicon on the axle, same principle...
I once got some blue locktite into the barrel of a carburator... couldn't move it for anything! Pulled the carb off the motor and dropped it in a pot of water and brought it just to a boil. Pulled the carb out and it came right apart.
#1741
AK
Just got my 110" 2 days ago, but already have almost everything I need to get it together. Here's my setup.
DLE-111
MTW headers into ES Composite pipes
Li-Ion batts, 2x 5200 on the radio, and 1x 2600 for the ignition
Power into a Smart-Fly PowerExpander Competition 12 Plus
Spektrum AR9000 with 2 satellites
Hitec 7955's all around, with a 5245 on the throttle... throttle servo plugged into receiver for regulated power
Kavan Air tires on PSP machined hubs
Graphics by Bad Brad Graphics
5" Mezjlik CF spinner
Custom CF baffles
Here's a pic of my 88"... the 110" will look the same.
DLE-111
Custom CF baffles
#1742
My Feedback: (29)
AZ
nice scenery......i too have a dle111 in mine, had a zdz100 for the 1st year and half, saw some dles at the field, bought a 55 for myself, liked it so much i pulled the zdz and put the 111 in it, definetly had more power, im diging this set up now, switched to a biela 28-10 and id say its darn near perfect for me, i have a vid on youtube i just made with that set up i can post a link if you want, my older vids shows the zdz, had a vess 27a mostly on that, much better now for sure
#1743
My Feedback: (17)
ID
Very nice picture.
My 110 has a DA100 on pipes. It's a great combo. I really like the plane.
You'll love yours I'm sure. And you setup sounds nice. It'll work great.
My advice.....double collars on the axles. Or better yet change them for the RPS (?) kind with the locking ring and then put a wheel collar.
My wheels fell off on the first 3 landings. Not pretty. But the damage was moderate each time. But my plane has been repaired 3 times and I only have about 25 flights on it. Something about the harmonics on my particular set up I think as others haven't had the problem. But I wouldn't take the chance.
Have a great time with this.
Barry
PS: Mines red.
Barry
PS: Mines red.
#1744
AK
DiamondDave, I'd love to see some video with the DLE-111. I ran the DLE-55 in my 88" and really liked it. I was planning to use a Vess 28 A or B on the 111.
Barry, I've got the PSP axles that use the C clips... I really like using the clips on my big airplanes. That and a little bit of silicon tubing pushed on the end of the axle as a last ditch to keep the wheel on. I've had to make 2 or 3 landings of smaller aircraft missing a wheel... it's always exciting! And not in a good way. ;-)
#1745
My Feedback: (29)
AZ
here is me doing some imac stuff with some "fun" stuff at the end, a good hover shows the dle power with the biela prop, i love this set up, f you click on my name you can see my other vids, a dle in my 88edge, and scroll around to see my older vids of my 110 with the zdz in it, i can see/hear a difference in performance too for sure
http://www.youtube.com/watch?v=kjRaoBHgWXQ
#1747
NJ
ORIGINAL: Stormrider5
Any word when the next batch will be here in the states? I have everything ready and waiting including the new 7x17 legend trailer.
Frank
#1748
GA
Container is supposed to be in the States. We are just waiting for the call for delivery.
Best thing is to drop me an email at [email protected] and let me know the airframe and color that you are interested in and I can keep you posted.
Curtis
Curtis
