If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 68 of 73 FirstFirst ... 18586667686970 ... LastLast
Results 1,676 to 1,700 of 1811
  1. #1676
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extreme Flight 110
    i found out something interesting today with my wolverine switch, i always new it had 2 switches and they were seperate, what i didnt know was it shares the battery juice after the switches are on, i finally set up a 2nd reciever in my plane cause i had an extra and figured why not be extra safe, well after setting it all up and splitting ele and ail to one side, i threw the switch, just one out of 2, and both recievers powered on, i double checked everything to see if i had a short or forgot to undo a Y or something, but nope is seperate one batt lead in each reciever, so i looked up the switch and it talks about sharing feature, so i think everything is set up correctly and thats the way its supposed to work, i tried to call them but they are closed until monday, anyway with just 1 reciever i never noticed it cause 1 switch would turn the plane on not matter what, well even 2 recievers 1 switch turns the entire plane on too, so now if one batt goes i still have both recievers, kinda cool, another benfit i was never aware of
    http://www.fromeco.org/Products/04FR...s/Default.aspx
  2. #1677
    Join Date
    Aug 2002
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    still haven't figured this out. yes i did try a y still same result. i ordered another servo should be in next week. ill post results thanks. someone said its pcm all together that i should go to 2.4. even though 2.4 is good and all and plan on getting it oneday. the lag was not there using same receiver on another plane using jr 8411.
  3. #1678
    JoeAirPort's Avatar
    Join Date
    Aug 2003
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe you can program the speed in the hitec servo programmer? I've never had to do this myself.
    Joe AP
  4. #1679
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you can program the speed but like you said you shouldnt have to, i had an issue with mine on the 1st few flights i would get a slight roll when doing a wall or popping into a hover, i thought my ele were even by eye, then did the stick trick and saw they were off, i redid the linkages to make sure they were even, from arm on servo to length of rod, it did correct it, was 85% better, then once that was good i did some flight testing for letteral balance of plane, power off dives with pull outs and stall tests, added weight to light wing until no drop doing either manuever, now i got to say this is by far the most balanced and true plane ive ever flown...but back to the servo thing it was my set up, if 1 arm is off a tooth and the other is off a tooth in the other direction, they wont be matched no matter what you do with linkages.....but last resort if all else fails you can adjust the speed of the faster servo, you cant speed the slow one up, you can only slow down the faster one....honestly if your not noticing it in any manuever you try in the air i would not mess with speed of servos
  5. #1680
    Termites Dream's Avatar
    Join Date
    Jul 2008
    Carmel, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys,
    need some advice. I am nearly up to the engine install, DL-111. I have everything for the plane except the exhaust. I have Xoar 27/10 and 28/10 props for it but can get a 3 blade if I have to. The noise restriction at my field is 91dB measured 25 feet from the centerline of the plane, averaged right and left sides. Should I use MTW TD 75 canisters or would RE-2 pipes be just as quiet? Or something else? I dont want to make a $500 investment and then fail the sound test.
    David
    \"The early bird may get the worm, but the second mouse gets the cheese\". David
  6. #1681
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bringing the thread back to life
    http://www.youtube.com/watch?v=qWZt0KrEMdw
  7. #1682
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice flying Dave. I like those spins.
    Charles
    Fly Extreme!
  8. #1683
    Join Date
    Apr 2002
    cary, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    im running a da100 on 2 ks pipes.
    can anyone running this setup tell me where they mounted there batteries.
    i just need a good balance point to start with.
    im using 3- 2300 a123 packs.thanx much
  9. #1684
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another Yak is born!!!
    I\'\'\'\'m in a jet!!! What could possibly go wrong?
  10. #1685
    diamondave's Avatar
    Join Date
    Sep 2004
    marana, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    looks good
  11. #1686
    taildragger21's Avatar
    Join Date
    Jun 2003
    park city, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Beautiful!! What engine??
  12. #1687
    cjcyclesrc's Avatar
    Join Date
    May 2005
    Belton, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: IFlyEm35
    Looks great!!
    Charles
    Fly Extreme!
  13. #1688
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: taildragger21
    Thanks guys! I am running a 3W-110CS. Just a couple things left to do before the maiden. We are actually building 3 identical ones that we are going to be using for a show team. The other 2 should be done in the next couple of weeks.
  14. #1689
    Join Date
    Jun 2003
    park city, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    aWESOME!!
  15. #1690
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks good, nice graphics. Seems you took those pictures near an airport.
    Jeff
    Extreme Flight RC, www.bandegraphix.com, team Airtronics
  16. #1691
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks! The pictures were taken at our flying field.
  17. #1692
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I thought it was a full scale runway or taxiway behind you in the first picture, but now I see it is a model airplane runway.
    Jeff
  18. #1693
    swk550's Avatar
    Join Date
    Apr 2003
    houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am using a DA100L with DA mufflers. I would like to convert to tuned pipes. What is the proper header drop when using tuned pipes?
    swk550
  19. #1694
    Join Date
    Jul 2008
    Carmel, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Header drop is 50mm. I got my RE2 pipes from DA. I wouldnt use DA again, the sales dude was incredibly unhelpful; then it took 7 weeks to send them instead of the one week they kept telling me whenever I called and then they sent me single pipe mounts instead of the double I ordered. Finally got it maidened, love the plane.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1440607   Click image for larger version.
ID:	1440608   Click image for larger version.
ID:	1440609   Click image for larger version.
  20. #1695
    Join Date
    Apr 2004
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry for the delay on your order. The headers come out of Germany and its out of our control as to when they ship to us. There was a mixup on the pipe mounts on our end which we promplty sent the correct ones overnight at our expense.
    Tony Russo
    Desert Aircraft Tech Support
    (520) 722-0607
  21. #1696
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some more pics!
  22. #1697
    Join Date
    Jul 2008
    Carmel, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fantastic! Those tail numbers would come in handy for formation flying. How did you decide who got to be #1 haha. I thought my club field was good, yours kicks *ss.
    Tony Russo of DA - thanks for your response. You are right that you did quickly overnight me the double pipe mounts after I called. The overall experience was just not what I was expecting, considering the good name you have in the industry.
  23. #1698
    gboulton's Avatar
    Join Date
    May 2005
    La Vergne, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Heading down to Georgia in the morning to pick mine up.  Can't wait!
    I will readily admit to being lazy, and not feeling up to sifting through 68 pages of thread.  *heh*  Would anyone care to take pity on me, and highlight any gotchya's or 'hey, look for this" moments I should be ready for in the build?
    Won't be my first 100+ airplane, nor the first time I've used the intended setup or equipment...so no shocks or worries there.  Just want to know if there's any common "tricks" for the bird.
    Thanks in advance!
    ‘ǝʌısuǝdxǝ sΔ± dn puɐ dn sΔ± uʍop \'\'\'\'pΗΚ‡ΙΉΗΚŒuΔ± puɐ ʍo1 uǝΙ₯ʍ
  24. #1699
    Join Date
    Dec 2001
    Georgetown, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gboulton
    Heading down to Georgia in the morning to pick mine up. Β*Can't wait!
    I will readily admit to being lazy, and not feeling up to sifting through 68 pages of thread. Β**heh* Β*Would anyone care to take pity on me, and highlight any gotchya's or 'hey, look for this'' moments I should be ready for in the build?
    Won't be my first 100+ airplane, nor the first time I've used the intended setup or equipment...so no shocks or worries there. Β*Just want to know if there's any common ''tricks'' for the bird.
    Thanks in advance!
    Follow the manual, that simple. (I am being serious too.) PM me with any questions as I wrote the manual and been flying this plane for over 2 years.
    Jeff
  25. #1700
    gboulton's Avatar
    Join Date
    May 2005
    La Vergne, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JWilliams
    heh! Good to hear!
    And thanks for the offer of help, Jeff!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
